Question about Uniden DECT 6.0 Cordless Phone System D1788-2 - Black/Silver
    New Friend:
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Posted on Feb 19, 2013
Need to reset speed dial numbers but cannot get the cursor to appear.
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
Speed dial option in Karbonn K451+ Gold champ
Hi Nilesh, the user's manual says, quote: "Speed dial: If you already set the speed dial numbers, then you can long press number key 2 to 9 to dial set numbers out under the standby mode.Long pressing number key 1 is to dial to voice mailbox if you already set the mailbox number." So it looks like you need to add the speed dial option in your chosen contacts details, first. Then follow the quote above. Good luck!
Dec 19, 2014 | Cell Phones
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
How to retrieve 1 week ago fax history from brother 2280 fax machine
Printing reports
How to print a report
1 Press Reports.
2 Press ? or ? to select the report you want.
Press Menu/Set.
Enter the number of the report you want to print.
For example, press 2 to print the Help List.
Following reports are available
Prints a Transmission Verification Report for your last transmission.
2.Help List
Prints the Help List so you can see at-a-glance how to quickly program your machine.
Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
4.Fax Journal
Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
5.User Settings
Lists your settings.
6.Network Config (MFC-7225N only)
Lists your Network settings.
Jun 11, 2011 | Office Equipment & Supplies
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
Feb 28, 2011 | Office Equipment & Supplies
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]{30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
Feb 10, 2010 | Brother IntelliFax-4100e Fax
Nokia 1100 speed dial problem
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
May 21, 2009 | Nokia 1100
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website ( under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
• Storing a number to a speed dial location will
overwrite the any previously stored number without
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Phone System D1788-2 - Black/Silver Logo
333 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
