Margherita al129x turn on but does not let wather in and nothing hapens! What is the problem?
  • izistyle
    izistyle Nov 05, 2012
    I put it on program and turn on, light switches on, and that click is heared but water does not start to run in! Help!
  • izistyle
    Is maybe electric water switch broken?
    New Friend:
  • 5 Answers
Door latch switch is stuck or faulty and washer thinks door is open and does not send current to water valve to start.
Posted on Sep 15, 2013
  • bob anadiotis Sep 15, 2013
    door latch switch is faulty or stuck and washer sees door open and does not send current to water valve to open as safety feuture.ifyou open top of washer you can access swicth and short out switch bypassing the three wires.
Coffee maker do not make hot wather
Hey it may be the heating element thats faulty
May 28, 2017 | Coffee Makers & Espresso Machines
My kenmore serie 300 washer only wash with cold wather no hot wather
If I understand, you are saying that you are not getting any hot water coming into the washer. First, I would make sure that you have hot water available at the washer spigots. SLOWLY unscrew the hot water hose at the hot water spigot and see if you have hot water available. If you do, the problem is usually at the water inlet solenoids, or if you are lucky, the water screen filter. Turn off the how water spigot and unscrew the hose at the washer. There is a screen there at the washer water inlet, see if it is clogged. If not, the problem is most likely the solenoids. To replace the solenoid unit requires some disassembly of the washer.
May 18, 2016 | Kenmore Washing Machines
The wather is not coming from cup
No wather? Sounds like you need to clean the ports on the heating unit. The manual should have the procedure for cleaning the machine.
Mar 25, 2014 | Coffee Makers & Espresso Machines
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Can't find instructions for discovery kids animated jellyfish lamp
hi i have the discovery kids animated jellyfish lamp. only put wather in the fish tank until the filter line, when you turned the fish inside the tank the air move the wather and jelly. good look
Jan 16, 2011 | Toys
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
Top Washing Machines Experts
