Question about Hunter Fan Company 5/1/1 Programmable Thermostat
BACKLIGHT DISPLAY ON HUNTER 44110 THERMOSTAT DOESN'T LIGHT UP
4 Suggested Answers
  • 5 Answers
SOURCE: Hunter Fan Company 5 + 2 thermostat #44110 Set and Save/Energy Star
i would say normal, between my family have 3 different hunter models, and they all do it.
Posted on Jul 11, 2008
heatman101
  • 43501 Answers
SOURCE: im replacing my honeywell with a hunter 44110 the
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 05, 2009
perkins48
  • 14417 Answers
SOURCE: I have a Hunter ceiling
I'm assuming your fan is connected to a switch on the wall,if it doesn't turn the fan or light on,as your remote doesn't,then your electrical wires have come loose causing you not to have power to fan,you will have to remove the parts to get to your wing nuts holding your wires together to make a good connection and put electrical tape over wing nuts and wire to keep together,vibration will cause them to come loose,make sure you turn power off at breaker.
Posted on Aug 29, 2011
Hunter Programmable Thermostat
My Hunter Programmable Thermostate #44110. I set it for regular clock time. But in the middle of the day and night it goes to military time. When I hadn't added military time. Is it time to buy a new one. I've had it for 8 years.
Apr 15, 2015 | Hunter Fan Company 7-day programmable...
Can not operate the furance, it just wont come on
Sounds like more is wrong than the thermostat. If gas heat,make sure the pilot light is lit and there is gas pressure.If fuel oil,you may have to press the restart button on the burner unit. or blead the the pump.
Sep 15, 2014 | Hunter Set and Save Programmable...
Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Jun 30, 2009 | Heating & Cooling
Changing to a digital thermostat
you cant use this thermostat . you have a trane 2 stage heatpump the hunter thermostat is made for a one stage heatpump ...if this answer helped please rate this 3 or 4 stars , this will keep me in the paid answer department
Apr 06, 2009 | Heating & Cooling
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Jul 04, 2008 | Hunter Fan Company 5/1/1 Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
184 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
