Question about Panasonic Kx-tda100 Kx-tda100 Digital Hybrid Ip-pbx Mai
I have 2 problems with KX TDA100
1. some numbers saved in the phone are not working e.g when i dial 106...it works and room 106 rings but when I dial 226 nothing happens and on screen display writes " reorder tone " 2. some numbers are not at the correct place..I mean when I want to call reception (0 number) the security rooms rings!!! please help me I have read whole the user manual but it didnt help me my mail address is mojtabaghanidel@gmail.com please please answer to my mail box thanks a lot my friends
SOURCE: How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Posted on Jun 17, 2008
mumma_1
  • 903 Answers
SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
Posted on Oct 28, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: no dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Posted on Jan 19, 2009
Phonesmith
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Dial lock
This worked on my KX-TG3611BX and might work on yours:
Turn the dial lock off using the following method:
1 {MENU} --> {#} -> {2} -> {5} -> {1}
2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
Aug 27, 2011 | Panasonic GigaRange KX-TG2432 Cordless...
I have PBX Tes824, Main phone kx-t7730 When it income call my office all phone ringing. Help me my english bad but i mean.
to ring only at extension 101 and 106,you can do this press *# 1234# press 408 speaker phone CON. press * CO1. Enable press right arrow key from 7730 phone CO2. mixed CO3. mixed CO4. mixed CO5. mixed CO6. enable press Auto dial store thats it
Sep 13, 2010 | Panasonic KX-T7730 Corded Phone
I have a Panasonic KX-T7030 Hybird system and mistakely hit the FWD/DND button that is now flashing and my phone dosent ring. How do I take this off?
I think you can press FWD and dial 0 to reset. If that doesn't work, try dialing 700+ your extension on the intercom. That should always work, no matter what system the phone is connected to.
Of course, if neither one works, please post back the model number of your SYSTEM cabinet (the white box in a closet, electrical room, back office, etc.).
Carl
May 24, 2010 | Panasonic KX-T7730 Corded Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
Ringing everywhere
If it used to work and stopped, I'm guessing the system is no longer in the DAY mode. Each system tends to program differently and the 7730 phone can be plugged into one of about 18 different Panasonic systems.
From the main phone, try dialing 780#. If it beeps and says DAY MODE, it was the right command :-) Now test the lines and see if that fixed it.
If it doesn't work, please go to the phone closet/back room/attic/whatever and grab the model number of the phone SYSTEM and post back.
Carl
May 11, 2009 | Panasonic KX-T7730 Corded Phone
Programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic Kx-tda100 Kx-tda100 Digital Hybrid Ip-pbx Mai Logo
79 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
