Question about Brother LB6800PRW Mechanical Sewing Machine
My lb6800 says raise pressure foot bar and it is, tried unplugging, nothing helps. It sews when embroidery unit not attatched.
I have unplugged and left off, but still have same error message raise pressure foot when the embroidery unit is attatched.
  • Brother Master
  • 7,365 Answers
It sounds like the sewing machine needs to be checked
to see if there is somthing wrong with the computer in the machine.
Posted on Nov 06, 2012
5 Suggested Answers
  • 3 Answers
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
Posted on Feb 05, 2009
  • 1788 Answers
SOURCE: I have a Brother SE-270 D how do I switch from
You can download your manual, downloads and a help section for free on the Brother website www.brother-usa.com. under the support section. They have a great site and very informative. Hope this answers your question. Good luck
Posted on Sep 13, 2010
Ezrahite
  • 2632 Answers
SOURCE: The error message "The safety
Welcome to Fixya. The error The safety device has been activated because of the reasons below:
  • The upper thread has become tangled around the bobbin case,
  • The needle is bent and hitting the needle plate, so the machine stops
  • You can also also refer to the website below for more information.
    Brother Solutions Center
    Thanks for using Fixya.
    Posted on Mar 03, 2011
    Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
    I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
    Dec 08, 2016 | PfaFF Creative 7570
    How do I Lower the pressure foot for sewing after changing from embroidery on my brother pc- 8500?
    Would a manual help?
    Brother PC 8500 User Manual
    Are the feed dogs in the raised position? Is it a regular stitch presser foot or a darning foot? A darning foot is shorter in height so the fabric can be maneuvered without use of the feed dogs. Just some ideas. Could also be an embroidery setting that has not been deactivated.
    Oct 03, 2016 | Brother PC-8500 Pacesetter Embroidery &...
    Why is there no drive to my machine.
    Try checking the clutch on the motor or maybe a faulty drive belt
    May 11, 2014 | Brother SE-270D Computerized Sewing...
    Computer stuck on "Raise presser foot lever" when I want to embroider
    I fixed myself. When you take off the front left cover to expose inner workings o0f pressure foot lever, move the pressure foot lever see, the small metal plate move, when looking from back of machine see a small post upper left rear with what kooks to be a spring, lightly touch causing to spring back to the left and you will hear a snap. This is realigning pressure foot and your embroidery unit will register and you will have a normal lcd screen.This helped me, hope helps you.
    Jul 19, 2012 | Brother Se400 Computerized Embroidery &...
    Where can I locate the fuse<
    The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
    1. Usingthe Sewing Machine
    1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
    2. SettingUp the Embroidery Unit
    1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
    Thanks for using fixya
    Jul 31, 2011 | PfaFF Creative 7570
    My sewing machine model no 9000 is showing a error is '' raise the pressure foot and needle bar then power on #01
    First, I would make sure the embroidery unit is unplugged if you r trying to sew and check the bobbin winder to make sure it is off. Also look for thread in the guide, these machines are very sensitive and when the slightest bit of thread gets caught in the tension of the threading format, the computer will automatically turn on error message.
    Sep 16, 2010 | Janome Memory Craft 9000 Computerized...
    Says raise pressure foot and needle bar
    check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
    hope this helps mary h
    Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
    I have a Brother LS 15 sewing machine
    raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
    thanks amy
    May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
    Brother LB6800PRW Mechanical Sewing Machine Logo
    100 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
