Question about Fisher and Paykel OR36LDBGX1 Range
Fisher and paykel range oven door will not stay open
I have done everything I can think of to get Fisher and Paykel to replace the door on my stove. The oven door raises on its own and the risk of being burned is high. I am told that there is nothing more that can be done by the authorized appliance repairman. He contacted the F&P sales/repair representative in our region and was told that nothing more could be done. I am FURIOUS. As an interior designer I have the opportunity to recommend appliances to my clients on a very regular basis. This would certainly color my recommendations on behalf of my clients.
  • Marla Grosko Nov 07, 2012
    can the hinges be adjusted in ANY way on these doors? There are no visible means of tightening
  • 1170 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
Posted on Mar 21, 2009
SOURCE: fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Posted on Jul 08, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Posted on Aug 03, 2009
  • 3247 Answers
SOURCE: Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Posted on Jul 30, 2010
Testimonial: "Good troubleshooting step I hadn't thought about. I tried it, but was unable to tell for certain when the water showed up - will try again."
  • 43501 Answers
SOURCE: I need a new oven thermostat for my Fisher and
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Posted on Jan 09, 2011
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ... > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ... > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Fisher paykel problem
sounds like you have a problem with the thermostat it may need to be replaced. \you can goole appliance parts and you will see a number of dealers you can get parts from
May 04, 2014 | Ovens
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Oct 25, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Remove scratches from top of stove caused by burner top pushed back by my daughter when cleaning
You can purchase special ceramic abrasive cleaner but I doubt it will suffice. There are other glass polishers but I suggest phoning the Fisher and Paykel customer service line for their recommendations. Cheers
Sep 12, 2011 | Fisher and Paykel OR24SDMBGX1 Gas Kitchen...
The door on my front loader won't open it has done a 30min cycle
my fisher and paykel door is jammed and is stuck on 1 minute timing won't start
Jan 14, 2011 | Fisher and Paykel Fisher & Paykel Washer
I need a new oven thermostat for my Fisher and Paykel free standing range. I am unable to locate this in South Africa and email to Fisher and Paykel remains unanswered.
Jan 08, 2011 | Fisher and Paykel Kitchen Ranges
F3 fault code on fisher & paykel wall oven.
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jul 14, 2010 | Fisher and Paykel Ovens
I have a Fisher and Paykel Saffron oven - stove top elements have started only working on high - unable to turn these down.
The temperature switching device has 'died', and needs replacing. This is a continual problem in these stoves (we have replaced each of ours at least once or twice in the 7 years we have had it). I will never buy another F&P oven!
The only solution is to get F&P or another repairman to come out and fix it. It cost us $AU 215 each time.
May 16, 2010 | Kitchen Ranges
Fisher and paykel B1600E multifunction stove manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Fisher and paykel stove/oven
This range has faulty simerstats they need replacing.
Jan 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel OR36LDBGX1  Range Logo
78 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
Level 1 Expert
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
