Question about Siemens OptiPoint 500 Basic Refurbished
Headset not working in opti point 500 basic
New phone but headset doesn't work? what do I need to do to make the phone accept the headset
    New Friend:
In order for a headset to work on that phone, you first need to make sure your headset is compatible with it. For example, our headset system:
http://www.aiheadsets.com/lxg-800.htm .
From there you would need to make the necessary switch adjustments on the setup . You are probably going to need a battery operated devise like ours. If you could provide your current headset model, I can help further.
Posted on Jan 04, 2013
When I walk inside my work building my cell phone doesn't accept calls, make calls, texts & internet isn't working. But when I walk back outside, it starts working again. Please help.
This building is preventing cell phone signals from reaching your phone. Try using your cell next to a window where signal are not obstructed by reinforced concrete walls.
Feb 15, 2012 | Motorola Cell Phones
I have new bluettooth plantronics220 but I try pairing it doesn't go trough. please help me
First you want to make sure that your phone is free of any other bluetooth interference. Disconnecting the battery of your phone for 30 seconds and reconnecting it helps to reset the phone. Then carefully follow the instructions on pages 4 & 5 from this link:
Plantronics Explorer 220 User's Guide
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to connect the planronics plx500 to the phone? what is the use of each one of the bottoms?
Unfortunately finding life on another planet would be easier than locating an ancient (electronic years) PLX-500 user guide. However, I happen to have one of those ancient writings (no, it wasn't in a cave at the Dead Sea), albeit a bit tattered and yellow, so I'll try and give you a rundown of it's various features.
The top buttons for headset/handset and mute, and listening volume wheel are pretty self-explanatory. Now let's talk about connecting the PLX-500 to your phone and the other amplifier features.
1) Disconnect the telephone handset cord from telephone base and insert the PLX-500 modular plug into the handset jack on the phone. You then insert the coiled handset cord into the back of the PLX-500 base (there's only one place it can go into).
2) Plug the cord from the headset into the jack in the front of the PLX-500.
3) On the back of the PLX-500 base there are two switches (1-2 and 3-4). These are used to configure your PLX-500 to your phone (most electronic single and multi-line phones, such as Panasonic, will use setting 1 and 4). You will have to configure the PLX-500 to your specific phone. Having connected your PLX-500 to your phone, put on your headset, press the headset button on the base, lift the handset of the phone cradle and listen for a dial tone. Adjust the switch settings until you hear the best dial tone.
4) Remember that your PLX-500 uses batteries located under a cover on the bottom of the base (some phones will work without your PLX-500 needing batteries, check configuration before installing batteries). Speaking of the cover, there is a small plastic screwdriver attached to it that you use for adjusting the volume of your microphone. That adjustment is located on the back of the PLX-500 base next to the configuration switches.
Hopefully this gets your PLX-500 up and running.
Aug 31, 2011 | Plantronics PLX500 Headset
Hi I have C7 headset, its secondary camera was working correctly until few days ago, from then it doesn't work... I don't know what's happened but when I select secondary camera,the screen of...
likely that the internal connection is loose. basically the camera just sits on a bed of contact points and a drop/knock may dislocate the points.
get it fixed professionally.
Jun 30, 2011 | Nokia C7 (8 GB) Smartphone
Does this device bluetooth aeon BTK-A20 work on all mobile phones or just nokia ones and if so how do i get it to work?
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
May 24, 2011 | Cell Phones
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
Jan 27, 2009 | Cardo scala-500 Wireless Headset
Motorola H-500
If you've set the audio input and output to the bluetooth and it still doesn;t work then you probably should try a different headset -- non-Motorola. Their radios sometimes are too weak. You can also try sitting closer to the PS3.
Jan 22, 2008 | Motorola Mobility Bluetooth Hands Free...
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Siemens OptiPoint 500 Basic Refurbished Logo
234 people viewed this question
Top Siemens Radio Communications Experts
Jon Piercy
Cliff itsasecret
Computer Links
Are you a Siemens Radio Communication Expert? Answer questions, earn points and help others
