Question about Digidesign Mbox 2 Barebone
How do i open the mbox 2 pro?
Please....how do i open the mbox 2 pro...something is loose inside and i want to fix it?
  • 1 more comment
  • corysaucier Mar 08, 2009
    There is something rattling around inside my mbox 2 and I can't figure out what it is, I need detailed instructions on dissassembling the casing so I can remove what ever it is rattling inside it, before it causes a short inside it.
  • Anonymous Mar 27, 2009
    I found two screws under the rubber "feet" of the casing and I did find the one under the CE label on the bottomof the box, but what else is there? The blue plastic front cover does not have any screws (at least not visible!)
    Is the abovementioned the same Mbox 2 Pro that I have?
    Mine does not have any "handle", so I didn´t find how to open the "allen key" part... Actually I didn´t yet find out how to open my Mbox.
    I have a bit of a similar problem and i have to get inside my Mbox!
    Could someone help me?
  • Anonymous Apr 22, 2009
    what else after removing the 3 screws under the label? blues plastic cover doesn't go out. please help
M-Box 2 Pro- 2 small black screws under rubber "feet" on the bottom(back)- 1 shiny screw under "CE" sticker on bottom- 10-12 small black screws under the faceplate sticker= DUMB- then one more small army of small black screws to get the faceplate off the metal casing-(remove carefully as there is a small ribbon connector from the faceplate to the chassis-pull up on small black sides where it connects to the faceplate.)- pop off top- reveals about a dozen small shiny screws holding the two "mother boards" together-left off there because I only needed to get to the volume resistor. good luck with the rest. good design too Digidesign.
Posted on Aug 03, 2009
There are five shiny screws and one black one located behind the plastic front label (the part that has the markings for the input levels and switches), plus three behind the serial number label, inside the handle part you open with the allen key. This removes the front panel, then, there are about twelve screws around the plastic casing, attaching the casing to the inner metal encasing.
There are three screws behind the foam strip on the metal casing, which attach a heavy duty metal strip to the inner casing... the rest are obvious.
This is how to deconstruct the casing in the event that something is rattling inside.
Keep in mind, if you still have a warranty on your MBOX 2, you won't anymore once you deconstruct it. So I don't advise it unless your device is well past warranty.
Though, if something is indeed rattling inside, I'm sure that's a breach of warranty conditions anyway.
You had best check on that first, but you might end up taking her apart anyway.
Posted on Mar 08, 2009
There is one more screw hidden under the bottom label (near the sign CE) just perforate thru it !
Posted on Mar 05, 2009
Mbox 3 pro not powering up...loose cable? can i fix myself?
yes u can fix it.... it happened to me yesterday ... i got a brand new m box 3 pro .... same problem!!!.... the power ware inside there is disconnected... u have to opened and plug it in ...
Apr 13, 2011 | Avid Pro Tools Mbox 3 Package (3rd Gen)
I just opened mine.. it had 5 screws on either side just under the blue plastic cover. if u want to do it nice, then just locate the screw by puttin somethin in there, and use ur screw driver to make a nice hole just above that screw. i really couldnt find an alternative way to open that damn thing.
Mar 27, 2009 | Digidesign Mbox 2 Pro FireWire Audio/MIDI...
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Jul 22, 2008 | Digidesign Mbox 2 Barebone
All the lights are on on my Mbox. it wont be recognized by pro tools. help!!
un plug it uninstall the mbox and all the asio drivers. update protools. then reinstall the mbox and all the asio drivers you should be fine.
Feb 12, 2008 | Digidesign Mbox 2 Barebone
PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
3,423 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
