SOURCE: Let my tank freeze and crack on the perfecta model
If the tank froze and broke it is highly likely the toilet itself may have a crack somewhere inside. You may buy the tank and find out later on the toilet itself it cracked. You have then wasted your money. Buying the tank and paying the shipping is more than likely about as much as a whole new toilet. My advice is to buy a new toilet.
SOURCE: need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
You need to replace the gasket in the fill valve if it is a problem that was not there when it was new. If it is new? Check the water flow from the supply line to the toilet. Turn of the water to the toilet, remove water line from toilet, run water into a bucket to check flow. @ the bottom of the fill valve where the water connects, on the inside there may be a screen that in plugged
