Question about Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo
How do I fix a PDA with general fault message? What can can suh a reading?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
General fault is the aqua pure either not enough salt or too much salt check salinty or the sensor or cell needs cleaning or replacing
Posted on May 21, 2014
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Tip
Dell PDA Battery Cover Warning Messages & Won't Power on
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solution.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
on Nov 26, 2013 | Dell Axim X51v Pocket PC
My remote shows aqua pure as a general default. I have cleaned cell but it did not change. System is not creating clorine.
In this case I would call the Jandy technical support. If it says it is in general fault then it means it will not generate chlorine. I hope this helps.
Aug 09, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
When trying to synchronize with PC an error box comes up with a message-"Error occurred while copying datablocks from handheld.This key is already associated with an element of this collection 457".
The person who supplied the program I was using advised me it was an error related to the date on the PDA. ( Something to do with Julian Calendars etc.) I use the PDA to transfer data from a soil moisture logger to my PC.
First I cleared all data from the PDA.
Then I loaded up the data (with correct date) from the PC to the PDA, and went out and restarted all the loggers.
I haven't done another reading yet, but if that worked I'll letyou know.
Regards,pvhoff.
Feb 09, 2010 | HP iPAQ HX2700 Pocket PC
I have message on pda "check AquaPure general fault"
SALT GENERATOR IS NOT WORKING OR SENSOR ARE BAD SEE AQUAPURE READING FOR CODE YOPU MAY HAVE TO CHAGE IT
Dec 06, 2009 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
My xbox 360 had red eye
in the beginning on the ring of lights?
Sep 05, 2008 | Microsoft Xbox 360 Console
Xbox 360
if it is under warranty maybe you can ask the manufacturer if they can replace it or yuo can try to check this forum website also:
http://forums.xbox-scene.com/index.php?s=a80517f4a3a729e4ea6e710fc69b944f&showtopic=656926&pid=4316084&st=0&#entry4316084
Aug 22, 2008 | Microsoft Xbox 360 Console
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Logo
154 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
