Question about Mitsubishi Televison & Video
Mitsubishi 72 inch tv picture is dark. I have changed settings to brighten it and nothing works. What could be the problem?
My tv picture has gotten really dark. Not sure what is going on. It turns on no problem, but the picture is just very dark, no matter how I change the picture settings. What is happening, is there something I can do to fix it? Thanks...
  • 579 Answers
SOURCE: problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Posted on Jan 02, 2008
  • 1694 Answers
SOURCE: 46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Posted on Feb 05, 2008
SOURCE: picture getting dark on my 70" mitsubishi projection
I FINALLY got the problem fixed!!! Gee I feel stupid. I called a great local TV repair guy and he came out and fixed it for next to nothing. The stupid part is that all he had to do was take apart the TV's front fascia and clean the mirrors and things inside....it was FILTHY!!! Then the TV was like new again. It looks so good I wanted to kiss him. He advised that you really should be cleaning that about once a year or so to prevent this problem. Also, I live in Nevada with HIGH dust so that doesn't help either.
Posted on Dec 05, 2008
rob52078
  • 40 Answers
SOURCE: why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Posted on Mar 13, 2009
SOURCE: My Philips Magnavox 50 inch projection tv picture
my philips projection tv model number 50pl9126d/37 has a dark screen
Posted on Sep 03, 2009
We have a Mitsubishi 73" tv that produces a dark picture. This tv came without a remote...where can we access the settings menu to brighten the picture?
You will need to buy yourself a Universal remote control that comes with a complete set of instructions to get tour TV to be controlled by it. After getting the on/off code working, go to the Menu and set up the settings.
Jan 12, 2013 | Televison & Video
Dark picture,can't get it to brighten up with menu color settings.
Assuming brightness and contrast (picture on some sets) does not help it could be a number of things, how old is this set?
Dec 15, 2012 | Sanyo DS25390 TV
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
72 inch Mitsubishi tv shows nothing but snow with slight picture behind it. I've reset it but no change.
It seems that the panel is defective. The video you shows here indicate it. Just check this link.
Sep 27, 2012 | Televison & Video
Picture on all channels is dark
seems like its the inverter thats either not working or the tubes are faulty
Mar 26, 2010 | LG 42LG50 42 in. LCD HDTV
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
Televison & Video Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
