Question about Oki Electric Industry C330dn Led Card Printer
Okidata error code 069 - Oki Electric Industry C330dn Led Card Printer
Hello I have an OKI C531dn printer that shows me a error message 069, what to do? help me
Service Call
069:Error Malfunction of the NIC chip was detected
Does this error recur?
Yes Power OFF/ON
Replace the printer control PCB
Jan 02, 2017 | OKI Office Equipment & Supplies
What is the problem on a okidata C5300 error codes 020
This code relates to a fatal error with the ROM. You may want to contact Oki # 800-634-0089 and see if they are willing to help.
Aug 14, 2014 | OKI C5300n Led Printer
Need codes for phillips tv or how to use code search
Hello
Universal remote code for Philisp TV with Innovage remote control are:
068 / 069 / 074/075/077/003/004/006/008/062/068/069/074/075/077/086/087/089/063/183/184/205/206/207/208/212/213
OK.
Jun 25, 2011 | Innovage Jumbo Remote Control
MB 480 OKI Printer Error Codes
you can some error code at manual
if you did not have manual you can download amanual at
http://www.german-parts.de/oki_manual/paperjam/stau_mb400_series.pdf
at that manual you can find some error code and how to fix it
Mar 12, 2011 | Oki Electric Industry Okidata MB 480 ...
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 08, 2010 | OKI C9600hdn Laser Printer
How do i clear an error alarm on my okidata 320? it wont do anything.
Power on then off, then unplug the unit for a few minutes. Then try it.
If this does not work post back.
Feb 05, 2010 | Matrix Okidata Microline 320 Printer
BATTERY SPECS FOR A JEEP GRAND CHEROKEE 2.7 DIESEL WHAT IS THE CORRECT BATTERY SIZE
Exide 031SE Exide Excell Car Battery (EX22) £76.79 Numax 069 Numax Car Battery 12V 68AH £55.99 Exide 069SE Exide Excell Car Battery (EX69) £76.79 Optima Optima Red Top RT S 4.2
(8002-250)
(BCI 34) RTS4.2
£149.05 Varta Type 069 Varta Asia Car Battery 12V 70Ah
(Short Code: E24)
(Varta DIN: 570 138 057 or 570 413 063)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
here are some batteries that will work . you can find equivilants to what ever your dealer carries .. :
exide 031se (EX22)
exide 069SE (EX69)
Numax 069 12 v 68AH
Optima RT S4.2 (8002-250) (BCI 34) RTS4.2
Varta type 069 12V 70AH (E24)
Oct 14, 2009 | 2003 Jeep Grand Cherokee
Error 063
Connect the printer to a PC and install the correct version of NetSpot:
http://www.usa.canon.com/html/download/netspotutils.html
NetSpot will diagnose your error codes for you.
Oct 04, 2006 | Canon imageRUNNER 600 Printer
Oki Electric Industry C330dn Led Card Printer Logo
232 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
