Question about Metra Honda Civic 1996
My 2003 Honda Accord radio will randomly come on, even when the car is parked in my driveway and is turned off and the key/transponder unit in the house. I'd hear the radio suddenly start playing, then turned off all on its own. I sat outside and waited to see it happen again - and found a pattern - when a car on the road approached my house, the radio came on, when the car has passed my house and was 25 feet out of sight, the radio turned back off - this happened repeatedly. Also when drivint around - when near airports, ambulance services, etc the radio will cut in and out (ie turn off and on) by itself. I bought the car used and it only had one key/transponder unit. The key got loose and fell out of the transponder, I glued it back in with gorilla glue. It held for 3-4 months before coming loose again - and I've repeated the gluing process 3 times now. Everything has always worked perfectly - but I am wondering if something about glueing the key back in the tranponder has effected something that relates to the radio. Anyone have any clue????
    Master:
  • 689 Answers
Tell your dog to leave the transmiter alone,LOL:
Posted on Nov 09, 2012
My 2007 honda accord has igination key problem,i remove the remote and weld a washer to the key. Now the car could not start,please what may be the problem and how will i fix it
Keys are fitted with transponders that are recognised by the car and allow the engine to start. If you have a key without a recognised transponder then even if the key will turn in the lock, the car will not start. You may have possibly damaged or even destroyed the transponder when you welded the washer to the key.
Jul 10, 2015 | Honda Cars & Trucks
2000 Honda accord wont start radio has anti theft light and key wont turn in ignition
No, make sure the car is in park and turn the wheel, this should allow to turn the key.------------------------------------------------------------------------------------------
Autel MaxiDAS DS708
Jan 09, 2013 | 2000 Honda Accord
Programming a honda transponder key
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
  1. Turn the ignition on
  2. Press Lock/Unlock within 4 seconds
  3. Turn ignition off and hen back on within 8 seconds
  4. Repeat steps 2-3 two times
  5. Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
  6. In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
  7. Switch ignition off and then remove the key
Civic 1996-1998
  1. Turn ignition on
  2. Press and hold the valet button which is situated on the radio within 5 seconds.
  3. System should now lock and unlock the vehicle indicating it is in the programming mode
  4. Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
  5. Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
  6. Release valet key
Radio remotes 2 and 3 button types
  1. Switch ignition on and repeat for 3 times.
  2. Press he lock button, switch the ignition off and back on and then press lock button again.
  3. System should now lock or unlock
  4. Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
  5. Switch ignition off to exit the programming mode.
If you will have any further doubts or question to ask i suggest you to check out the page where i found this which is http://www.carkeyadvice.com/step-by-step-fob-programming-guides/honda :) i hope this was the solution you were looking for mate! happy happy new year!
Dec 30, 2012 | 2007 Honda Pilot
I have a 2003 Honda accord that will not start! Tried to jump battery..all fans and belts were running however car would not turn over...bought a new battery and replaced with old now my car want do a
I have seen issues like this on other Honda's and the problem turned out to be the ignition starter switch. Do this, jumper power directly to the starter solenoid trigger wire and see if the engine cranks.
Jun 30, 2017 | 2003 Honda Accord
Honda Accord check engine flashes when tapping brakes
Engine light flashing along with the drop on RPMs is indicative of misfires. Connect a scan tool and see if any codes are stored this may give you a starting point. As for the clicking I'm not sure that it is related to the engine light but clicking when braking may be due to worn suspension/steering parts such as control arm bushings
Mar 10, 2012 | 2003 Honda Accord
2006 honda accord: key stuck in ACC position. won't turn to O position to remove from ignition. car starts fine and is in park.
The same thing happened to my 2003 Honda Accord...took it to the dealership, and they had to replace my shift lever entirely. Something about the cable between the ignition and shift lever not being read correctly...(basically, my car is not reading that it's actually in park and therefore won't release the key)....
Nov 09, 2009 | 2006 Honda Accord
03 Honda Accord. Keys no longer work.
you are having a problem with your immobilizer unit. the key may just need to be reproggramed. this can only be performed by a honda dealer with a honda diagnostic scan tool
Oct 26, 2009 | 2003 Honda Accord
Turned key and starter turned over until battery died
This sounds like the sylinoid is bad. Di you check it.
May 18, 2009 | 1997 Honda Accord
2003 Honda Accord radio keeps on running when engine turned off
Should be covered under a recall. But they are very strict about the exact problem and I got swindled out of 500 bucks. The radio should be replaced as it will turn itself on and off - even the volume! Bit disconnect radio means you disconnect the panel, too.
Mar 10, 2009 | 2003 Honda Accord
Metra Honda Civic 1996 Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
