WHAT IS THE PPT20 FOR 03 RAV4
PLASTIC HOUSING CASE CONNECTED TO THE POSITIVE CABLE ON THE BATTERY
  • joecoolvette
    joecoolvette Nov 05, 2012
    How does Toyota RAV4 problems get into PC Laptops?
  • 1118 Answers
SOURCE: 1989 oldsmobile cutlass ciera 3.3L V6, plastic housing
New kick down cable, that cable is for your passing gear, easy chg. unhook from throttle and take little bolt out that holds plastic peace on trans and you will see how its connected in trans. it will look like a little piece of wire with a bend in it and the end of cable will have a hole that slips over to connect it to cable. You will understand it when you see it.
Posted on Feb 04, 2009
pops296
  • 174 Answers
SOURCE: When attempting to jump start the vehicle positive
Sounds like a dead short. May be the battery. Not sure what hooks to it as I don't know the year of the vehicle. Disconnect the battery cables and see what it does. Make sure everything is off before you connect the cables. If it arc's when you hook the cables up, there is a short somewhere.
Posted on Oct 01, 2009
SOURCE: 1993 Buick century Battery dies after sitting for
From what I get,you have a battery (12.31 Voltage Drop) all the time
No way all the fusable links are out of system
That is kind of extreme to cut them
Go to 20AMP first, and put the meter back in series,as your were.
If you get anything over 30 Mili Amp ,and it doesn't time out after 10 min,you found the issue.
The fuses out ,should have killed that.
Posted on Nov 07, 2010
  • 1949 Answers
SOURCE: how do you install a car battery? The battery has
with an 8mm wrench remove the bolts to the cables
Posted on Dec 07, 2010
  • 1403 Answers
SOURCE: there is a wire attached
the car started and run before? if so, bypass the wire with a wire connection kit from autozone or advance auto,it may be a metal fuse link for an added stereo,or another application. it may even be a fuseable link. if so take it off, then go to parts place and do not be afraid to ask questions!you may have to buy an application to car to make it run safely.so what!i would sleep better knowing i did not give you wrong advice.disconnect the application, take it to autozone, advance auto,nappa. and find out what the application is. you cannot go wrong by doing that, don't be afraid to ask questions! if i could see it, i would be able to tell you what to do and how. but i can't thank you for choosing fixya.com
Posted on Dec 31, 2010
Hi I recently bought a 2000 Nissan Altima and I absolutely love the car. Anyway my question was about the alternator wiring. I happened to notice a red wire that was fed directly to the battery from the...
What size is the wire from the alternator to the battery, is it the main battery cable, or is it a small aftermarket piece of wire someone has fitted?
There will be an earth cable onnected to the rear of the alternator housing via a 10mm headed bolt, and a positive cable connected to an insulated thread with a 10mm headed nut, and only a grey plug connector cliped in.
Should be no other wires unless someone has ran a wire from the positive battery connection for axillary equipment.
Feb 26, 2018 | Nissan Cars & Trucks
I'm getting ground from the positive battery cable pulled fuse after fuse individually but my tester light stayed on.
Well it would. Everything is connected to the positive battery cable including things which are working and connected to the return (the ground). Things like the clock, the radio and the ECM are permanently connected when ignition is off.
Also from the way you connected the tester, between battery terminal and battery clamp, you are measuring amps drawn. So you are measuring the amperage drain of the things which are still connected and running.
Jul 18, 2016 | Cars & Trucks
2006 suzuki boulevard m109r battery help please........I'm trying to figure out why the positive battery terminal is getting hot enough that it melted through the plastic battery cover
Greetings, Dude. Unless there's a hot pipe near the battery, the melted battery case could be the result of a serious short circuit somewhere along that positive cable. On advisement, resistance in a conductor causes heat, so be sure to ascertain that the cable connection AT THE BATTERY is not corroded or otherwise compromised. This could be a dangerous situation. Automotive batteries emit hydrogen gas during the process of charging and discharging. This gas could cause an explosion if a spark occurs nearby. Thus we need to insure that the connections are near perfect. If your battery case is cracked or otherwise compromised, take it out of service and dispose of it properly. Good Luck. Herb
Mar 03, 2015 | Suzuki Motorcycles
How do I change the starter for my 2006 Chrysler Sebring touring
You'll need a set of metric sockets and end wrenches. Then disconnect the positive battery cable. Wrap the terminal you removed from the battery in a rag and secure it away from the battery. Follow the positive battery cable down to the engine block. It will most certainly be connected to the starter. Remove the cable and any other small wires. Make a diagram showing where to reconnect them. Remove 2 14 mm bolts from the starter to bell housing. Remove starter. Reverse the procedure to install new one.
Jan 26, 2015 | 2006 Chrysler Sebring
I can't figure how to get the battery installed in my Q grill. I assume it is in plastic housing behind the cradle part, the housing enclosing the igniter button. If so, does the housing separate from...
The igniter button unscrews and the battery is inserted with the Positive (+) tip facing in. eshould be no need to open the igniter box housing.
In case you have misplaced your Owners Manual, I have an included a link to it that you can download and print for future reference, Pat close attention to Page 6.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q100120200220_OwnersGuide_41061_020708.pdf
Hope this helped you and Happy Grilling!!
May 13, 2011 | Weber Q100 Grill
Took old dead battery out don't know which terinal is negative and which is positive
the terminals on the battery will have a + (positive) or a - (negative) moulded in the plastic case within 1/2 inch of the terminal.
if it is the cables you are not sure about, the negative cable will go straight to the body of the car.
Mar 02, 2011 | 2001 Hyundai Accent
Were is negative. Battery post
The negative battery cable is black and the positive battery cable is red.
The positive battery cable will lead to the starter while the negative battery cable will connect to the body of the car which is negatively grounded.
Always remove the neg. battery cable first, and then the pos. battery cable second. And install in the opposite direction, pos. battery cable first, and then finally the neg. battery cable to the battery.
Also, many batteries have the (+) and (-) posts labeled in an embossed fashion on the plastic case.
Do not reverse, or else the vehicle's electronics can be fried.
Good luck on this repair.
Dec 15, 2010 | 2005 Chevrolet Equinox
The batery dont take charge
check it with a multimeter and make sure that its showing some voltage, if it isn't then lift up the blue plastic housing on the battery and verify that the positive and negative terminals are connected
Jun 01, 2010 | Peg Perego John Deere Gator HPX
Wiring on top of battery case looks to be melting
The wire that is getting so hot may have gotten chaffed and shorted out. do you have aftermarket accessories connected ? They may be drawing too much amperage.
Feb 17, 2009 | 2003 Volkswagen New Beetle Convertible
Computers & Internet Logo
David Payne
David Payne
