I have a Magnavox 32MD357B LCD TV. The picture suddenly changed to something like a negative image. Mostly the blacks are light which affects any dark colors. Is there an easy/inexpensive solution?
silly girl
  • 513 Answers
SOURCE: SONY KLV30HR LCD TV RED EFFECTS
You probably need to replace the backlight. In parts less than 30$. If you know your way around these things, or know someone who does, it's not a super difficult thing to do. You can get a tutorial that's written for monitors here: http://www.inventgeek.com/Projects/shorts/lcdfix.aspx basically the same procedure for an LCD TV. Good luck!
Posted on May 25, 2006
Sparko1
  • 167 Answers
SOURCE: The picture on my Vizio 42
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Posted on Aug 04, 2009
rhozel2010
  • 269 Answers
SOURCE: Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Posted on Sep 04, 2009
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
SOURCE: i have a sony 32m3000 color is dark and red also
@circuitworld: You claim in your profile that you repair plasma and LCD TV's, but you just told someone with an LCD to replace the convergence IC's and linear buffers. First off, convergence IC's are in rear projection TV's not LCD's, and the buffer boards are in plasma's, again, not in LCD's
@gardenwc: Typically what you are experiencing is a bad video controller or an actual faulty panel, the latter of which is not cost effective to replace.
Posted on Feb 02, 2010
Magnavox #32md357b/37 it has a inverted picture like a x-Ray picture tried to color on it and it won't adjust to natural color
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 20, 2016 | Magnavox Televison & Video
I have a magnavox tv 32md357b lcd when i turn it on it goes on then off what can i do to fix this
Hello
There is some shorted components on the main baord to this TV. You have to check it out, and locate the exact one. This is a skilled job. You must have through knoledge in electronics to do this work. Sometimes, the main digital board may need replacement.
http://www.dataentryjobs.us/67948.html2_18_2012_2_13_39_am.jpg
Feb 17, 2012 | JVC AV-36950 TV
My camera fell down, everything is working properly. But when I take picture the image is a bit green at low light area, and when outside in the morning the image is worser u can't see anything...
it is definitely something bad with your lcd screen.the screen is very thin and easy to chipping.
you need to replace the lcd screen,or it will affect the camera normal working.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN/E-mail:e-8090team@hotmail.com
cindy
Aug 20, 2011 | Canon Cameras
Magnavox 51MP6200D/37, when watching, the picture faded to black and then the sound went within a minute. now the power light just blinks and to turn it off we have to unplug it.
maybe you set it in freeze mode or timer.... the blinking reason mostly is for freeze and standby mode.... try to rest your program in tv.
May 27, 2011 | Vizio L32 32 in. LCD HDTV
My 2 year old Magnavox 37MF231D/37 LCD TV just blew the picture screen. The audio comes through fine, but the screen is dead black with no menus, info, nothing. I tried various inputs, same result. I...
The problem can be in the backlight inverter board (hard to get to), or the main power supply module may not be working. Look at the power supply first since it is easy to get to, look for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please
Nov 11, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Feb 21, 2009 | Televison & Video
TV picture was warped, no it is black, but the power light remains on...
the problem you are having is in the power supply you can go ahead and take your set to a repairman o look at your set good luck.
May 02, 2007 | Philips Magnavox MS3652S 36" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
