Remote not working prorerly and freezing.
The Remote Control buttons would only work sometimes.
Then it just froze, and you could not do anything on the Remote or the Set Box. Could not even turn it off on the Set Box. Had to turn the power off at the wall, waited for a short while and turned it back on.
Turned on OK, but still with the same problem of poor control on Remote.
  • ritual_nous Jan 05, 2009
    Thank You b_stro804 for your prompt reply.
    I have already changed the batteries in the remote to better batteries.
    We received the Set Box for Christmas, and have had nothing but trouble since attaching it to the TV.
    It has also had another problem..........
    When watching the TV, all of a sudden it just stopped working, went to a blue screen.
    We just left it like that, did not press any buttons, and by itself it just went and scanned for stations, so now we have double up of all of the stations.
    But the channel selection is better on the remote now.
    Strange!!!!!
    Cheers
  • 68 Answers
Change the batteries in remote. try not to use off brand batteries. listen for any parts that may be broken in remote. sometimes the connectors in the remote may break
Posted on Jan 05, 2009
Remote control unit does not open the door. we
You can try reprogramming the remotes to the opener that is not working. Sometimes they get a brain freeze and drop the codes and reprogramming can fix it. Next to where the wire hangs down will be a colored square button (the learn button) press once and release, you have 30 seconds to try and program a remote, you don't need to do all in the 30 seconds. Press and hold the button on your remote that you want to use until you see the light on the opener blink or hear a click sound from opener, let go of the button. it should now be programmed. If you can't get any of them to work then the logic board is bad.This repair can cost as much as a new opener + install. Sears sells a "remote control conversion kit" it comes with 1 remote and a plug in receiver you attach to your existing opener. 2 wires come off it and hooks up where your wall control hooks up at the openr.It's pretty easy to install. FYI the remote controls are color coordinated meaning the buttons on the remotes have to be the same color or they won't work, so if existing remotes are not the same color as the one in the kit they will most likely have to be replaced. good luck!
Jul 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Harmony Remote 1000 controller has froze with start up screen, how do i get to main menu
Hi. Try doing the following to get your remote working again,
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
That usually takes care of my remote when it freezes. (:
Feb 15, 2010 | Logitech Harmony 1000 LCD Touchscreen...
Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Apr 07, 2009 | Samsung TV Remote Control
Remote is froze and says safe mode
Remove the batteries. Hold in the Number 2 button. replace the battery while still holding 2. continue to hold 2 until it says upgrade success. then hit activities and your good to go.
Jan 27, 2009 | Logitech Harmony 550 Remote Control
Phone Has Froze HELP
hold power button in on phone while its connected to computor or hold while it is disconected has worked on other things that i have froze using computer
Jan 01, 2009 | Samsung SGH-U600 Cellular Phone
Unit "froze" Is there a reset?
I had a similar problem with a MX-3000 2 years ago. The unit would continually freeze. I think it was a problem with the first few units. Since then I've bought a new one and had no problems. Then this weekend, it froze for the first time (the battery is not holding a charge so I think that led to the problem).
If you open the back cover, there is a silver button just above where the battery plugs into the remote. Pushing that button should perform a reset. As an alternative, you can remove the battery at the connector. It is recommended that you use the button and not the connector. It is in there tight on my unit and pulling on the wires can cause a break.
Gary
http://twitter.com/GaryHuff
Dec 16, 2008 | Universal Remote Control MX-3000 LCD...
Remote control won't program.
my remote quit working. do you have a solution? thank you
Nov 14, 2008 | RCA 3-Device Universal Remote with...
Freezing up
I heard holding the menu(power) button, and record button down restarts the device...Idk if it works though. Just a suggestion
Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
Mx-3000 just froze up
This happened to me today. I plugged the programming cable into the MX 3000 and the screen became "un-froze."
Jan 08, 2008 | Universal Remote Control MX-3000 LCD...
Freezes; sometimes resets by itself?
Most likely, it's your hard drive. It can be replaced, so you don't have to junk the unit.
Nov 23, 2007 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Electro Med Services...
