Question about Metrologic Instruments 9520 Voyager
The scanner seems to be scanning the barcodes but they do not show up on my computer
The lights come on and the laser scans but it doesn't show up on the computer
SOURCE: ms9520 buzzez and then will not scan
The Razzberry Tone is what I'm hearing. Acording to the trouble shooting I should return the unit for repair. Thanks for you help!
Posted on Jun 07, 2007
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
SOURCE: Metrologic USB Voyager scanner
refer your scanner manual and scan the default barcode printed ,then scan the use interface barcode printed properly
Posted on Feb 02, 2008
  • 18 Answers
SOURCE: Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Posted on Apr 02, 2009
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
Hi all i am trying to use barcode scanner in Motorola MC55 Handheld Mobile Computer. i have installed data wedge from...
Hello, Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
Oct 11, 2010 | Motorola MC55 Handheld Mobile Computer PN...
I have plugged it in, and the laser is on but does not work. It beeps when I scan a barcode but the computer nor the epos software is reconising it. Hlpe!
Make sure the correct port is selected in the Symbol software (or whatever program you are using)
You can check if the scanner is functioning by opening a new "text" document and then scan a barcode and the results should show up in the text document.
If that works then it's probably just your software configuration...
Good Luck!
Oct 10, 2009 | Symbol Cyclone M2004 Handheld Barcode...
My mc9090-g doesn't scan any barcodes
you can download MS active sync from microsoft website. then connect the gun to your computer to sync it. Once it sync, drag the barcode app to the windows folder in the gun.
Dec 02, 2008 | Symbol MC9090-G Barcode Scanner
Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Nov 23, 2007 | Symbol MC1000 Barcode Scanner
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
May 31, 2007 | Datalogic Gryphon D200 (901661076)...
Metrologic Instruments 9520 Voyager Logo
22 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
