Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
12inch l7's rattle or sound really distorted on low pitch bass
My system sounds good until low bass hits the cone moves drasticly and makes an unpleasant ratling sound i have 750.1 kicker amp hooked to each
  • 1 more comment
  • aaronpierce4 Jan 05, 2009
    thank's but i've tried that before friend of mine says it may be my stock radio that comes in the ford f150
  • aaronpierce4 Jan 06, 2009
    thanks for the help last night i changed wires from parallel to in series and that helped alot now i've got to get a new radio peace!!!!!!!
  • Anonymous Mar 18, 2014
    We bought a comp c12 12" kicker and it started to make a buzzing sound the voice aint the same and the bass anit that laud
    President:
  • 1,990 Answers
You need to lower the Gain just a little.
Posted on Jan 05, 2009
  • Travis Humphries
    Travis Humphries Jan 05, 2009
    Very well could be. The first thing that I do when I purchase a New Vehicle is Replace the Radio and Build from there. Except for the Scion Xa that I bought-It had a Pioneer System from Factory! You cannot rely on the Factory Installed Radio's Once you have started Connecting Amp's and Crossover's Because they were not Built for that. I would get a Head unit and Install kit and Start Fresh from the Head Unit Back.
  • Travis Humphries
    Travis Humphries Jan 07, 2009
    No Problem! Happy to Help!
Kicker solo baric l7 12" has distortion at low volume. What could cause this?
It sounds like the cone is distorted. If it's a paper cone, it may have gotten wet. If it's a poly cone, it may have been exposed to too much heat (sunlight?).
Also check the wiring; anything loose may make a rattling sound.
Last, the problem may not be in the speaker at all - it may be a problem with the amp.
Jul 29, 2014 | Car Audio & Video
How can replace the speaker the bass sound is broken
Dear Rob,
Really Thankful for the detailed description for the Speaker Repair.
It really helped me a lot. I have a unusual situation here with me. I have dissected the whole console and found the outer band of the speaker has just come off....have attached photos to make it clear. does the outer speaker cone will make a difference or i will have to replace the speakers itself.....when i checked pressing the speaker down and played the distortion had gone....but while playing without holding the distortion would come back....Hope you can help me in this situation....Thanks in Advance..... 714812a0-935e-4f95-922e-50c6ba281b9c.jpg 36e62701-6370-491a-a317-a11c69cc9525.jpg
Jan 13, 2013 | Harman Kardon Go + Play Portable Speaker...
I have 3 JL Audio 12
Reduce the amount of boost or, better yet, turn off the bass boost. With your installation, overemphasis on the bass is causing the rattles and distortion
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
When i first bought my alpine type r 12's they were perfect bass really loud but now they aren't as loud i think the cone inside messed up
If the cone messed up there would be a lot of rattling. Most likely the subs have just gotten broken in and won't sound as loud as brand new. Over time and with use a subwoofer magnet will start to weaken. When the magnet weakens it won't hit as hard anymore.
Aug 15, 2010 | Car Audio & Video
Im a candidate sound engineer, im strugling to set the bass drum from the mixer. how do i set it?
Bass drum by convention is ch1 on the board.
You need a good drum and a good mic
First set eq flat and pfl ch1, set gain control so drum just hits peak/or red when hit hard.
Send ch to drum group (1+2) on board, or route to master (L+R), depending on type board. Then listen to drum ONLY through the system, and adjust eq so it sounds good at low level then turn it up and keep it sounding good.
If it keeps peaking the ch then turn down gain.
There are toys (inserts) you can use noise gates and compressors if available,
Sound is objective and can not be learnt without doing it , good luck. remember good low level sound will always be better than really bad lound sound, start low make it good then make it loud.
Good drums do not need much eq. Get the drum right first.
Hope this helps
Thanks for using FixYa
Aug 06, 2010 | Samson SX1200 Amplifier
Blown?
Typically you will hear a popping sound when the bass hits, or you may not have any sound at all.......If the sub sounds good then your ok.
On a side note, pulling on the cone while the sub is in operation can damage the unit because it cannot move freely under load
Sep 25, 2009 | Clarion SRR6923 Car Speaker
Db drive vs kicker
The Kickers are the way to go here- they move more air because naturally a 15 inch square has more area than a 15 inch circle- thus more air moved =greater spl =LOUDER. The only thing that might get some equality between the two is if the db drive round sub has a far greater xmax that is the linear movement of the cone from start to full excursion-IF the db drive has drastically larger xmax than it could possibly outperform the L7 because of greater cone excursion which also =more air moved=louder---- haha thats a tricky one but ya got me wondering too so let me know what you find out please-Ive always been a kicker fanatic so im probably biased towards their products-never heard nothing bad about db drive though either im in salt lake city i dont know of anywhere out here that even carries their products so i have nothing to reference by except kicker L7's kick asssssssssss
May 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Craking sound
its either a bad voice coil or your amp is under powered while hitting good bass, could try a CAP or replace your car battery
Mar 16, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Bose Lifestyle 35 Accoustimass module rattles at high volume
Well to be hones 85 sounds pretty loud to me, generally the bose acoustimass module shouldnt really be distorting or crackling unless under extremely high sound levels.
It could possibley be that the speaker cone in the bass module has a slight perforation so it would distort at high levels. However other problems could be loose connections inside the unt or outside the unit. If your friend doesnt have it above 85 under normal circumstances I wouldnt worry to much about it but if there is a tear in the cone the problem could get worse.
Nov 27, 2008 | Bose Acoustimass 15 System
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
277 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
