Question about Coby MP-705 Digital Media Player
The ipod is not turning on
I plugged in the ipod and it charged then turned off and i cant turn it back on. i have reset it and even tried turning it on manually. it didnt work
  • sotang Jan 07, 2009
    I HAVE THE EXACT SAME PROBLEM LOL., it is really anoying . mp4 video is anoying, i need the right codec for it.
  • sotang May 11, 2010
    just to say, first it is not an ipod :), second you can't make a diagnosis based on that, information needed 1.)how long have you had it? 2.)what activities have you done with it (or to it) need more information then you can be helped easier. otherwise try to get refund or a new one.
No solutions yet. be the first one to submit a solution!!!, i have one........GIVE UP.
Posted on Jan 07, 2009
Ipod does not power up
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Mar 24, 2013 | Apple iPod Audio Players & Recorders
My ipod cant be turned on even if i charged it. i try another connector and charger but still it cant be turn on
i lost an iPod this way as well
What happens is sometimes the battery can go so low
to the point the ipod does not have inof charge
to charge it back up, thus resulting in a dead/drained out
battery
Replacing it can be done but its a very delicate
procedure
that takes experience, therefore it may be best
to move on
Oct 05, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
IPOD touch got very hot and then turned off and won't turn back on
I tryed those, my ipod will not turn on! This morning it was slow, then froze and turned off and got REALLY hot... I got home (7 hours later) and its cooled down but i cant turn it on? I tryed plugging it in and resetting it, but it wont turn on! it was almost a full battery when it died/turned off..
Nov 06, 2009 | Apple iPod touch
My ipod nano wont do anything
try reseting it with holding down the menu and center button. Your warrenty will have been voided due to the liquid damage though so if you cant get it working with the reset your gunna need a new one.
Apr 17, 2009 | Apple iPod nano
Ipod won't do anything, not even charge
my friend had the same problem, try resetting the ipod. or it may have water or being dropped damage
Jan 13, 2009 | Apple iPod nano
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
Won't turn on
tammy,
It sounds like you either need a new battery pack, or the iPod itself has to be replaced/upgraded.
Please let me know if this helps. Take care!
Feb 28, 2008 | Apple iPod nano
Ipod not turning on or charing with computer
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
If you need more assistance let me know. Good luck.
Jan 31, 2008 | Apple iPod nano
My 1week old ipod shuffle 2nd gen wont turn on
i got mine downloded music listend to if for about 2 weeks mabye and it was all fine..The i went to use it the next day it it wouldent turn on at all i tried to reset it adn all but nothing works....im useing windows vista so no problem there but on the ipod theres not lights and it seems to get hot while charing for a small amount of time..lets say maye 30 mins its pretty warm...is this a li po battery problem or what?
Aug 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Coby MP-705  Digital Media Player  Logo
29 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
