Question about Kenmore Microwave Ovens
Kenmore microwave 721.66490690 not working
Light are on and you can use all the buttons but when you cvlose the door nothing happens
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't START!!!!!!!!!!!!
It's usually a broken tab on the upper switch holder, allowing the switch to rotate just out of position.
This tab can be hard to see, since it is under the bottom edge of the switch.
While replacing the switch holder is the preferred solution, using hot glue to secure the switch to the holder is much easier and quicker. Just be sure not to let the door be slammed from now on.
We have the R1480 service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: F2 WArning light on Kenmore Microwave oven
The light bulb already works, so this isn't the problem.
Posted on Oct 01, 2008
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
  • 1214 Answers
SOURCE: Whirlpool microwave cook light turns on but oven does not work
Check and replace the door safety switch.
Posted on Feb 15, 2009
The kitchen timer button does not work on my Kenmore circular wave microwave.
If it has membrane switches, you might have a bad switch. Or, you could have a bad connection between the touch panel and the circuit board. Or the circuit board itself could have a problem.
Jul 25, 2016 | Kenmore Microwave Ovens
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
Microwave refuses to work when START button is pressed. Oven light stays on when door is closed. Control panel seems to be working ok but nothing happens after cooking settings are set and START button...
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Jan 11, 2011 | Whirlpool MH1150XM Convection/Microwave...
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
Power on lights etc push start button but it clicks and nothing happens
Hello :
This could happen because of bad door switch or a loose door mount .This is the main reason that microwaves not heat even if the other functions work fine .
Warning : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please rate !
Apr 04, 2010 | Panasonic NN-C994S Convection/Microwave...
Kenmore Microwave Hood Combination 721.80019 does not heat. I follow all the troubleshooting procedures. Nothing solved the problem. Help!
My kenmore microwave will not work. The light stays on inside, buttons will push, but the start button does nothing. I've tried everything. The last thing I did was express defrost which was fine. Could it be something really simple? I hope so.
Nov 14, 2009 | Kenmore 63792 Microwave Oven
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
New Kenmore microwave won't start
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Not guaranteed to reveal the trouble, but sometimes it does.
There's a good chance it could have been bumped in shipping, causing misalignment of the door hinges or switches.
Jul 29, 2008 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
