Question about Motorola Radius P1225 Two Way Radio.
Motorola p1225 flashing light
The red light on top (normally the transmit light) is flashing when inserted in the charger. What does this mean?
3 Suggested Answers
SOURCE: motorola h715 been connected to the charger for
my H715 motorola bluetooth headset mute is on and I can't turn it OFF! HELP!
Posted on Aug 14, 2009
SOURCE: motorola h680 has no sound but a flashing red light.
I have same issue, worked perfectly for about year, then all of a sudden when I receives a call I could not ear anything. The other end can ear me, and I can make commands to my phone still but, I hear nothing.
Posted on Mar 05, 2011
When I put a battery on the charger either only the red light flashes or all three lights stay on steady. what can I do to fix this problem
The flashing red means a short, or bad battery. It is not 100% accurate. Sometimes you can leave the battery on the charger for an hour or so and pull and reinsert it and it will charge. Check: battery at room temperature, then battery contacts on both the battery and charger. Clean them. Power cycle the charger, which was unplugged when you cleaned it, right? Sometimes, a pocket will go bad. The 3 lights I do not know about.
Oct 26, 2015 | Motorola NTN1177 Rapid Multi Unit Charger,...
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
My Motorola HK250 wont charge is flashing red all the time
Mine is too. Mine will sit solid red for a little then turn solid blue. Then after that it will flash red all the time. I've had it on the charger for the last 2 days and that's all its been doing. I read the flashing red light means the battery is either unchangeable or not making proper contact.
Oct 22, 2013 | Motorola Mobility HK250 Universal...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I have a gp300 6 port charger, when charging the red charge light flashes, what does this indicate.
What does the little sticker on the bottom of the charger tell you? It seems to me that a blinking red light means that the battery is so old that it will no longer take a charge and that it's time to replace the battery.
Mar 28, 2012 | Motorola Radio Communications
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
Mar 19, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Motorola Radius P1225 Two Way Radio. Logo
71 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
