Question about Home Security
All-o-matic garage door opener receiver clicking does not open or close door at times
Transmitter green lite comes on but door does not go up or down at times. Hear clicking up near receiver when transmitter is pressed.
Garage door opener does not open at times with the wall switch or the remote. It just clicks
Posted on Mar 10, 2013
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 3197 Answers
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Posted on Apr 30, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
Mrteaze
  • 101 Answers
SOURCE: Garage Door will not stay closed.
You need to check the adjustment for the travel of the door ... All automatic closers have a built in safety mechanism that prevents children, pets and even yourself from being crushed by the door ... so if the travel is set to low the door will hit the ground too hard and safety mechanism will activate opening the door again! Look at you documentation for how to adjust this for your particular model :)
Posted on Sep 29, 2009
When the door closes, it automatically reopens. There are no obstructions so that isn't the issue. If I disconnect the door and cycle the automatic is closes and then immediately reopens.
make sure that the auto matic reverse circuit light is being read correctly. they is a light extending a beam of infared light, you can't see it, to a reflector across the garage at the floor level at the garage opening. There should be an indicator light, usually green and red. Line up the light and reflector until the green light comes on.
Mar 08, 2011 | liftmaster Chamberlain Garage Door Opener...
DOOR CLOSES MOST OF THE WAY AND THEN OPENS. LIGHT THEN BLINKS TEN TIMES. I NOTICED THAT ONE SAFETY SENSOR IS GREEN AND ONE IS YELLOW. PLEASE ADVISE.
Hi. The sensor with the yellow light is telling you that it is miss-aligned, Usually it only takes getting bumped to knock them out of alignment.
I would slowly turn or adjust the positioning of the sensor.
The one with the yellow light should turn green when it is all the way in line so that the beam is completing it's path.
It's out of adjustment, so the sensor is looking at it like there is an object blocking the door from closing.
It's called the obstruction sensor.
It's there as a safety feature, so that the door doesn't come down and smash anything in the opening.
I hope this helps you out.
Feb 04, 2011 | liftmaster Garage Door 1/2 Hp
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
One of the sensors on the side of the door is yellow, the main unit hanging in the garage has a yellow light, and it only closes if we hold the button down. otherwise light blinks and it kicks back, like...
senor are obstructed, gently wipe off the lenz, look for any dust, cob webs or loose wires.
make sure the eyes see each other ( look for the lites on the side) one green and one yellow, tap on to make sure they do not flicker, move them around until you have a strong steady lite and then tighten down. this should solve your problem
Sep 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Trying to clear the codes from my Garage Door opener. 41A3615, 139.53615SR, Grey Learn Button, '92 mfg date. I added a Klick universal wireless wall pad and a Klick universal remote and now my neighbor's...
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Mar 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens whenever it wants to
In most cases, when a garage door opens or closes by itself, or when you find your door open, up returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes ta continuous signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button which can also go bad. It is a process of elimination.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Transmitter not working ( 3 of them)
don't hold down green button. push for one second. do yu have console with vacation or lock button. deactivate it.
Dec 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
All garage door transmitter would not work
The lock is probably engaged. Look at the wall button, the green light is probably flashing. Hold down the lock button for 3 seconds and light should be solid. Your remotes should work now
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
421 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
