Question about Cell Phones
Error while saving to U disk
Error while saving ti U disk and Reinitializing
Display says Redializing...
If the display reads "reinitializing" but does not come to ready, your first troubleshooting step is to disconnect any USB or Network cables attached to the printer and restart the printer. If you still get the error, then likely the formatter on the printer is bad.
May 08, 2015 | HP LaserJet 3700n Printer
Error 1308. Source file not found: E:\PC\TI-NSP~2\Program Files\TI Education\TI-Nspire\locale.properties. Verify that the file exists and that you can access it.
Maybe the file is missing, or there is a defect on the disk. I suggest you go the education.ti.com website and download the trial software from there. Install it on your computer and validate it with the license that came with your calculator.
Jan 19, 2012 | Texas Instruments TI-Nspire Graphic...
How do I print a TI-84 screen?
You can capture the screen by use of the TI Connect software.
  1. Connect the calculator to a computer using the TI Connect software.
  2. Run the TI Connect software.
  3. On the calculator, create the screen you want printed.
  4. While the screen is being displayed, go to TI connect main window and click the button SCREEN CAPTURE..
  5. Once screen is captured, save it.
  6. By default TIConnect saves captures in .bmp format, but you can change it to other formats by clicking the down arrow in Save AS window.
  7. Choose jpeg or appropriate format.
  8. Once saved, the image can be printed.
Aug 12, 2010 | Texas Instruments TI-84 Plus Calculator
E:62:12
hi there
the error code is teling you that one of the sensors is stuck, you may want to try tapping the camera on both sides and the bottom this useually losens the sensor that is stuck and solves the problem, try tapping it on a table top.
Nov 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Photo numbering
I have found a solution, albeit for MacOS X (v10.5)
1) Take a dummy picture. 2) Connect the camera to the Macintosh computer. 3) The camera is mounted as a "NO NAME" disk. 4) Open the subfolder "100NIKON" in the folder "DCIM" 5) Rename the "DSCN0001.JPG" picture to "DSCN5050.JPG" 6) Eject the camera disk. It is done! 7) Take your picture, and delete the dummy one.
As far as it goes, it seems to work for me. Number sequencing will start at "DSCN5050"
AB
Jul 06, 2008 | Nikon COOLPIX Cameras
Errors F03 et error U99
After months of U99 errors, I was able to fix my unit by reinitializing the defaults while using a CD-R with a firmware fix downloaded from the internet. Power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this.
Jun 14, 2008 | Panasonic Televison & Video
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
