Question about Philips 51PP9200D Television
My Philips 51PW9363 has pink and green colors only!!!!
My Philips 51PW9363 has no color when connections are made on any of the inputs and with different equipment, the only colors are pink and green and a slight 3D like effect around the edges of some of the images, the set is about 41/2 yrs old what do you think the problem is??
  • Philips Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
My Philips 51PW9363 has pink and green colors only - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Want to change the convergence chip in my philips projection tv model#51pw9363/17f
Has a projector tv model 50p8341 philips that has a pink color to it work fine but the color, has a new board in it going to throw it in the trash is 10 years old if you no anybody that need parts let me know. no one can tell me what is wrong . would you no?
Feb 19, 2013 | Philips Televison & Video
Unpluged my computer to get repaired, have 3 different speaker type plug ins the back, don't remember which one to use. Their color coded, blue-green- pink
In many cards, the microphone connector will be pink, the speakers or line out or headphone will be lime green, and the stereo line in will be light blue. Additional jacks may be present on newer soundcards for rear and mid surround speakers.
This is a widely accepted color standard for computer sound card input and output jacks, but connector colors may vary between different brands. If you think you have a nonstandard card, consult your soundcard's manual or the manufacturer's web site before making any connections.
Apr 13, 2011 | Computers & Internet
I have a Dell Dimension DIM300. Where is the input for a two-pronged headset?
I guess you are referring to a Head phone and microphone set, with the cable splitting at the other end into two jacks. Most probably one a pink (or rose) colored one and the other green colored. Not necessary though, sometimes these two can be same color with indentation on the plastic surface to identify which one is Microphone and Headphone. If this is what the information you are looking for look on the back side of the computer. You will see three sockets in one column. If the computer is relatively new chances are that the surrounding area of these three jacks are also colored pink, green and blue. Match the pink jack to the pink (head phone) socket. Like wise green (ear phone) to green. Leave the blue one. If the computer is an old one, you may need a relatively close inspection.You may see a circle with an arrow going in to represent Mic and a circle with an arrow pointing outward to represent ear phone.
Mar 05, 2010 | Dell Dimension 3000 PC Desktop
When moving the 51pw9363 will the color be affected by weather and movement, TV's color was good and then moved to the basement now the color is all messed up tried the convergence seem to have no effect
Usually temperature will not have a big affect but high humidity will. I would suspect the convergence amps have possibly developed loose solder joints from the move. They are mounted on heavy duty heat sinks that can move a lot and crack joints. Hard to say. Thanks for using fixya.
Dec 22, 2009 | Philips 51PW9363 51" Rear Projection...
Distorted picture and pink and green color only
Are you using the 3 wire component video input. If so commonly the wires are switched or one is bad. be sure wires are color matched on both ends.
Nov 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Philips 51PW9363 looks like someone is pinching the screen in the middle from the top and bottom. No color, sound or other problems that I've noticed.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 22, 2009 | Philips 51PW9363 51" Rear Projection...
Pink and green with double writing
this is a internal problem you should call 1-888-PHILIPS (744-5477) to set up service. It is usally a main board problem
Jan 08, 2009 | Philips 52PFL7432D Television
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 51PP9200D Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
