Question about GE Profile JTP56 Electric Double Oven
JKP56BOA2BB BOTTOM OVEN ONLY GETS TO 100 DEGREES
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I am attempting to pre-heat oven to 400 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Posted on Dec 09, 2009
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Hotpoint oven gets too hot
it needs to be calibrated, please get a service tech
May 10, 2014 | Hotpoint Ovens
Hi Experts! I'm having problems with my Ariston FO87CIX oven. The oven turns on but if I try to set the temperature the oven turn off and the time resets. It's weird but I've worked out that any...
One of 2 things, either the pt100(sensor) is faulty, or the control is defective. Unfortunately you need a digital multimeter to check the sensor first. When in doubt, replace both and all will be well.
Sep 09, 2010 | Ovens
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
Thermador SC302T won't reach temp (stuck at 100 degrees)
Sounds like you have a real POS on your hands. I would chuck it and get another unit rather than waste any more time and money on this Thermador.
Jun 20, 2017 | Thermador SC302T Electric Double Oven
Oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
May 09, 2009 | Ovens
Not heating up
Hi.
I suspect you may have a faulty oven element, which is breaking down as it gets hotter, disconnect element and try if ,if it does not trip, then element is faulty
Nov 20, 2008 | AEG U7101-4 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
35 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
