Question about Electrolux Washing Machines
4180N washing machine
We want to decrease the spin revolution on this machine. It's possible ?
wagdom
  • 64 Answers
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Posted on Oct 31, 2007
duby1990
  • 367 Answers
SOURCE: my whirlpool washing machine fills & goes
You need to replace the drive coupler which is located between the motor and the transmission.
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 22, 2010
SOURCE: homemaker hmwm8000 washing machine. clicking noise
they wanted me to buy a manual, but all i did was get a pointed knife, and in the bottom centre there is a cap, remove this and get a rag and clean out gunk, there is a phillips head screw, undo this and pull out bottom aggitate plate there is a washer too that belongs underneath thier, i found $3.60 in loose change, then reverse steps to put back together, happy washin
Posted on Jun 02, 2010
MNTECH
  • 1543 Answers
SOURCE: LG Washing Machine Model :
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Posted on Mar 15, 2011
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
Dec 11, 2012 | Washing Machines
Hotpoint WMA33 washer- The machine was in a final spin after a 95 degree wash when the power to the house was tripped by the washing machine, since then the machine will not start, all the lights come on...
Possible the surge would have made some changes in the main processor memory or damaged the processor. You can shut down the washer and remove the plug for few hours. press down all the panel buttons to drain all residual voltage on the board.
If the same fault repeats then it is possible there are errors on the board.
Jul 25, 2012 | Hotpoint Washing Machines
W3240 washing machine displays '---'
Possible that the pump is cloggged , remove the pump and clean , if ththere is dirt, fabric or foreign particles it cannot pump and so will shut off the processor.
check this link for tips; Pump
May 31, 2012 | Miele Washing Machines
I have a Frigidaire model FTF2140FS1, front loader washing machine, works great till the final rinse, then there is a noise that is in tune with the revolutions of the tub, sort of a thumping like som
It will most likely be the start of a bearing failure, it will get slightly louder the faster the drum turns, it's not an easy job to replace but it can be done.
Mar 10, 2012 | Frigidaire Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
My washer won't spin. It stop and gave me a warning "UE". What is this mean. Please help me.
I have a LG LNC6753A71 the washer agitates drains rinses but won't spin. The motor runs but it won't spin.
May 01, 2011 | LG WM0642H Front Load
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Mar 15, 2011 | Washing Machines
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
