Question about Maytag Neptune MDG5500AW Gas Dryer
Gas smell in maytag dryer
Gas smell when opening door
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You have a gas leak from the gas valve being faulty. DO NOT use the dryer until you have replaced the valve! I have been doing appliance repair for 15 years and I have seen 7 homes that have burned down due to this very same problem. Please don't use the dryer! Here is the new gas valve to order.
Keep me posted!
Posted on Nov 06, 2012
docjohn174
  • 943 Answers
SOURCE: Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Posted on Sep 18, 2008
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
garing
  • 998 Answers
SOURCE: maytag gas dryer MDG6400AWW heats up for 2 minutes
turn gas off to dryer. For safety it is best not to wait get your gas company to find leak(i don't think they charge for that)if it is at the control valve you should take the screws that hold the coils down out.Remove coils and rubber O rings and replace all with new ones it comes as a kit
Posted on Aug 19, 2009
Smell gas inside maytag dryer when i open door . not commimg from piping leading to dryer
Your exhaust to the outside of the house is restricted some where between dryer and wall to the outside. If the vent is restricted then it cannot exhaust the fumes, heat and moisture to the outside of your home like iit needs to do.
Nov 14, 2016 | Maytag Dryers
The pilot light isn't on and wont light up, no smell of gas either. The dryer was working normal I thought, open the door and the clothes weren't dry.
You will need to replace the Thermocouple. You can purchase one at your local hardware store, the instructions will be with it. Very easy to repalce.
Sep 14, 2011 | Maytag MDG7600AW Gas Dryer
To stop gas smell after opening dryer door
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer will not heat and I can smell gas when I open the tub.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Internal gas leak of Maytag MDG5500AWW
if the flame is not a clear blue,rather an orange/blue or orange, the gas is not being completely combusted, either the burner orfice tube needs cleaning or the air to gas ratio is off and needs more air intake and this can be adjusted also
Sep 30, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer MDG6400AWW heats up for 2 minutes and that's it everything else runs. and twice I smelled gas when I opened the dryer door. the timer was replaced 2 years ago. Is there another problem?
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My kenmore gas dryer has a very strong smell of gas when I open the dryer door. Can you help?
I hope this work for U
copy n paste
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174214
Was this helpful?
Feb 28, 2009 | Maytag MDG2706A Gas Dryer
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
472 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
