Question about Pride Celebrity X 3-Wheel Electric Scooter
My celebrity x will not start. Battery is charged, lights and horn are working but motor won't start. Free wheel lever is in drive mode.followed all suggestion but still no response. Can u help as
Motor won't start. Checked all wiring and engaged and disengaged The free wheel lever. The battery indicator goes all the way down To the right. Horn and lIghts are working. Pls help
3 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: I have a pride gogo
  • What that flash code indicates that there is that the battery voltage is to high to operate the scooter. This can happen for a number of reasons and from out of no where. The manual says you should contact GoGo for this problem. But I know a couple things to try and if they do not work then you need to contact GoGo.
  1. First remove the battery connectors for 5 full minutes and see if that resets it.
  2. You may have a wire that got caught up somewhere so check all wires for breaks in the insulation, cracks etx.
  3. Check the fuse as well.
  4. Push in the main circuit breaker reset button (see diagram)
  • Here is the GoGo Pride Scooter website should you need to contact them and if what I listed does not work then you need to. The things I list are some at home troubleshooting tips GoGo does not offer. They say to contact them immediately. http://www.pridemobility.com/contact.asp
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 16, 2011
gewiz
  • 1263 Answers
SOURCE: Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Posted on Oct 12, 2009
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Have a1993HondaShadow Stopped at storean won't start,nothinf will work.Lights horn Etc.
First check the main fuse, then battery connections,then check battery for voltage,ignition switch. If your battery went dead you need to check the charging system.
Oct 26, 2012 | Motorcycles
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
Battery fully charged,horn works but no power to drive wheels
Make sure your freewheel brake is in the DRIVE position. Check your owner's manual for the location of the free wheel lever, ususally it is near the rear of the scooter. If the chair is in DRIVE mode but the wheels will not turn, you may have a motor problem which would require replacing the motors.
Oct 11, 2010 | Golden Technologies Avenger 3 Wheel...
Pride Celebrity X 3-Wheel Electric Scooter  Logo
137 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
