Question about Delta None Dropside Portable Solid Wood Castered Feet Crib In Cherry
How do I get a certificate of compliance for a portable crib
Style - 4470-100 Lot sy 10267 Mfg date 12/16/2010 Order 252894
How can I order a Manuel and certificate for a Sheffield Stages crib white, model # 04510-241 January 2011. Need to keep info on file for my daycare.
contact the manufacturer direct as they are the only people who can issue a certificate for the crib
they will also have a manual for it as it will be a requirement under safety law
Dec 21, 2016 | Baby Gear
Where do I get a certificate of compliance?
from the manufacturer or retailer
if it is brand new out of the box, the certificate should have been included with the assembly /warranty sheets
Feb 10, 2016 | Baby Gear
We purchased 4 ethan mini cribs in December 2011 and have been unable to get a certificate of compliance. We have been calling the manufacturer and have gotton no where. All cribs made after June 28
manufacturers and importers by law have to comply and fit a compliance plate to the equipment or supply a certificate with a serial number for each unit
If they fail to respond to a request for that compliance certificate or plate , contact you r government authority ( work health and safety) and notify of a non compliance with the regulation
Mar 25, 2017 | Nursery Smart Ethan Petite
How to get a valid yahoo certificate update because mine got expired
Hi there, the simplest way to resolve certification error is by fixing your computer's date. If the clock's date was set wrong, then it sends expired security certificates. I hope that helps.
Jul 07, 2011 | Computers & Internet
I have the Cosco 10-T58 crib that I use in my family child care home, with the new laws on cribs going into effect I have to have documentation of the following: o Ask the manufacturer, retailer,...
I have the same crib and am facing the same problem, all I can figure out is to call the Cosco customer service, the number I have found is 1-800-544-1108. Hopefully we will get good news.
Apr 18, 2011 | Cosco 10-T58 Portable Crib
I would like to know if this crib model has a recall " model # 4624-1" date of Man. 03/24/06 Thank You
Here is a link to check using the date of manufacture and model and style.
They used a finger pull style and a shin push. Just follow the directions
and they will send you a free kit. It does appear there is a recall for it.
http://www.cribrecallcenter.com/recall.asp?pa=1
Mar 05, 2011 | Delta Luv Normandy Crib
I have no idea who the manufactor is of my Jenny Lind crib. All I know is I purchased it at Foleys department store in 1980 and I need all the hardware for this crib. Where do I get this from?
A Jenny Lind crib is a style I believe. There are and were many manufactuers of this style. Simmons Juvenile products used to make these but I believe they are out of business.Evenflo currently makes a Jenny Lind crib. You can buy/or use, used Jenny Lind cribs but it is strongly advisable that you don't. Older baby beds don't comply with today's safety standards; if you are buying/using a baby crib you may even be unknowingly buying one that was the subject of a recall. If you do go ahead a by a used one make sure it has JPMA certificate. Try to find the serial number somehwere and check for recalls. You can find a new bed for less than $100.00 new, that might be lot easier and safer than finding the parts.
Aug 17, 2010 | Garden
I need the hardware (bolts, etc.) for the following crib: Model 4842-2 > > Order P8640028 > > Mfg March 2006 > > Delta LV Crib I would like to order them on-line. How do I do...
You can order the replacemant parts on the manufacturer's website by clicking this link:
http://www.deltaenterprise.com/order_parts.asp?pg=order_parts
On the page which opens, enter the Model number and the Lot number in the boxes provided and click the submit button.
For further information and assistance for ordering the parts, contact the manufacturer's customer care by clicking this link
Hope this solves your problem. Thanks for using FixYa.
Jun 18, 2010 | Delta Enterprise Versailles 4970 Crib
Jenny Lind crib instructions...
Jenny Lind is a style of crib, not the mfg
DaVinci makes Jenny Lind...
http://www.milliondollarbaby.com/instructions
If you find your model, go to the Customer Care and click order parts
May 30, 2009 | DaVinci Jenny Lind Crib
Jardine Black Olympia lifetime convertible crib
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
Apr 03, 2009 | Baby Gear
Delta None Dropside Portable Solid Wood Castered Feet Crib In Cherry Logo
207 people viewed this question
Top Delta Baby Gear Experts
Paul Carew
William McDowell
Are you a Delta Baby Gear Expert? Answer questions, earn points and help others
