Question about Daewoo DVDRW11 DVD Recorder
Does not record
My dvd recorder does not record, but will play dvds. what could be the matter?
Will not corresponse with my sky box there is no sound but will record programme
Posted on Aug 28, 2007
  • 1003 Answers
SOURCE: DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Posted on Jan 14, 2008
SOURCE: Won't play dvds.
Hi, All. I found this discussion based on a Google search because I was having the same exact problem with playing Superbad on my Philips DVDR3400 after renting the movie 3 times and confirming the DVD played on my computer, etc. The good news is I was able to fix this problem. Go to Philips support at http://www.support.philips.com/support/html/index_us_en.html From that link, enter the model number of your DVD player into Search. Select your player from the list that comes up, and on the next page select "software & drivers" link at the left. This will take you to the firmware upgrade for your exact model which updates the software that runs your DVD player (also, when trying to find your exact model..such as mine was DVDR3400/37...you can find it on the label on the underside of your DVD player or it is on a sticker on the back side of your user manual). This takes you to both the link for the software download as well as detailed instructions on how to do it which are very clear. That includes how to use your remote to check that the version you will upgrade to is newer than the current version on your DVD. This was quite easy so long as you are comfortable with downloading the software to your PC, unzipping and then ripping to a recordable CD disc. You will then put that dics into your DVD which will read the files and upgrade itself. The whole upgrade process on the DVD itself took about 5 minutes. When it was done rebooting after it upgraded, I powered it off/on. Then I played Superbad, laughed and had a good time ;)
Posted on Feb 17, 2008
  • 476 Answers
SOURCE: Playing recorded DVDs on PC or other DVD player
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Posted on Mar 02, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
SOURCE: DVD Recorder/VCR 80 GB HDD
Tyr using -r dvds ,,,,,that might resolve your problems
Posted on Oct 07, 2008
Will play commercial dvds but will not play home recorded dvds
The home recorded dvds disc have diffrence finalizing codes,that the Panasonic dvd recorder doesn't share those codes.That why u can't play those home recorded dvds discs.
Oct 24, 2010 | Panasonic DMR-E55 DVD Recorder
Philips DVD recorder, records dvds but won't play them
possible playback head damaged
Please rate my help++++Thanks for using Fixya
May 29, 2010 | GPX D108S DVD Player
Dvds recorded on video to dvd recorder wont play elsewhere
Mosr DVD recorders have a "compatible" setting or require you to "finalise" the disc. Check that is being done.
It's also worth checking that the laptop will play other DVDs sometimes you need a codec.
Jun 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Burner on DVD Recorder; it neither records nor plays DVDs
through experience, bring to a tech nearest you.its either the lens or the mainboard or mpeg is faulty.
May 27, 2009 | iLO DVDRH04 DVD Recorder
PLAY REGION 2 DVDS ON DVD RECORDER
Press "Setup"
Go to "Lock"
Press 0 seven times.
Press "Return"
Dec 23, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't play recorded dvds on other dvd players
are you finalizing the discs after recording? some recorders do this automaticaly others have it as an option you have to select.. without finalization they will play on your own recorder but not on other machines.
Oct 07, 2008 | Protron PD-DVR100 DVD Recorder
Mar 25, 2008 | Televison & Video
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Daewoo DVDRW11 DVD Recorder Logo
124 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
