4003000f get hw setting failed
512
I HAD IT WORKING FOR A MONTH SINCE I GOT IT AND WHEN I WAS TEXTING IT JUST WENT BLANK AND STARTED SHOWING.HW CHECK FAIL. WHATS HW? AND HOW TO I FIX IT, PLEASE HELP! THANK YOU.
HW usually stands for Hardware - I think you might need to do a factory reset (check the manufacturer's website for instructions on how to do this - usually some combination of pressing and holding the on/off button and volume buttons) and see if this fixes it - I woldn't be too hopeful though - it's likely that something within the phone is broken or has come loose from its internal connector - has it been dropped or knocked hard?
Apr 12, 2015 | Cell Phones
My phone shows HW check fail. The service provided by Motorola help centre is really sad. please help
HW Check Fail, just indicates the hardware is not working correct. Cam be anything from a lose contact and bad memory or a defective chip. Without a tech and a repair shop, you won't be able to use it again. Sorry
Mar 29, 2015 | Motorola Cell Phones
Radio error codeURC HW error
code URC HW error: HW usually stands for hardware which means some part of the electronics has failed. Without a model number I can't look up the code "URC" but I'd suggest you do a search on the web for "Motorola model ##### error codes"
Oct 25, 2013 | Motorola Radio Communications
6500 Slide Cellular Phone: hw i make configuration setting...
to get gprs setting
u just call CC and ask them to send the setting
they have all settings for ur phone
becoz ur using nokia phone
May 06, 2010 | Nokia 6500 Slide Cellular Phone
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
Hw cn i download my sony ericsson software in my computer?
Go to sony ericsson website. Download PC suite from there and then connect your cable to PC and njoy transfering data.
May 25, 2009 | Sony Ericsson T700 Quad HSPDA 3MP Blk...
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
55 people viewed this question
jasbo
jasbo
