Question about Vacuums
My Vax S2 Steam Stick has stopped producing steam
I have a Vax S2 steam stick. It's suddenly stopped steaming, the green light is on and it makes a noise but no steam comes out. What could be wrong?
    New Friend:
What is CLR???
Posted on Jun 03, 2016
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
heatman101
  • 43501 Answers
SOURCE: My steam mop all of a sudden stop steaming. The
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
jr
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: I loved my Shark Steam
heatman101
Posted on May 19, 2011
  • 11800 Answers
SOURCE: Mop stopped producing steam while
In this unit the steam is generated by the boiling of a liquid. It doesn't matter what liquid: water, tea, wine, even gasoline - as long as it boils you can use it.
The heat needed to make the liquid boil is generated by a simple resistance controlled by a basic thermostat - if the temperature of the resistance goes over 100C the power to the resistance is cut. So in your case either the thermostat or, most likely, the resistance has failed.
Unfortunately there are no replacement parts for this unit - it's a use and junk device that is cheaper to replace than to repair. Sorry, time for a new one.
Posted on Aug 09, 2011
I have a vax steam mop it was working perfectly
possibly not heating if you have water and no heat it could be a problem with the heating cycle that allows the steam to work .
You need a technician to have a closer look at it. It could be something small like a wire off or it could be major like an element problem. Take it in & ask for a quote on getting your machine working again.
Sep 01, 2014 | Vacuums
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark Pocket Steam Mop suddenly stopped steaming. We've had this over a year. This is the first time that it hasn't steamed. It doesn't make the "steaming" noise that it used to when you...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
[][];';'l;
Jan 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi Our H20 Mop is just over 12 months old and when we start it up the red LED light will not change to green nad will not steam up. When you run your hand down the machine you can feel a little bit of...
Hello
Our (POS !!!!) H20 Mop is just over 20 months old,suddenly became inoperative....
At startup,LED lites red,shortly thereafter changes to green,however NO steam out unit & an audable 'humming'
type noise comes from the unit.
Whatcha got ????
Alf
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Oct 29, 2010 | Vacuums
No more steam coming out.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Apr 19, 2009 | Bissell 1867 steamMOP Stick Vacuum
Vacuums Logo
4,743 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
