Question about LG Televison & Video
My tv fixed stand keeps coming loose and the tv leans foreward
The stand affixed to my tv keeps coming loose making the tv lean foreward like its going to fall over
  • 191 Answers
SOURCE: affixing 42" TV to stand
employ a technical expert to measure the diameter,type & length of the screw to fix.
Posted on Oct 11, 2008
SOURCE: 3 in 1 Exersaucer Pond Stage 3
Go to www.evenflo.com. Click on your product at the top and then on the right side there is a "related link" for product instructions. You will need your Model # and Manufacture date (which is on the seat of the Exersaucer). Then it will list all the parts available for that product. Almost all the way down is a pdf version of the instructions that you can download for free. I used it and was able to assemble my Exersaucer to the 3rd stage. Good Luck!
Posted on Feb 27, 2009
  • 19 Answers
SOURCE: lte5243dq6 tub broken loose
I had the exact same problem. I was able to find out that the suspension rods are prone to this problem and Whirlpool had actually replaced all of them with a new kit part # that comes with 3 new suspension rod springs and replacement instructions. The old part # is 3406201 and the new part # is W10207783. When I called Whirlpool parts and expressed disappointment over the fact that the washer/dryer combo is just over 1 year old (and thus out of warranty) and that they recognized the poor construction of the original parts by the fact that they have a new kit to replace the 'defective' ones, I convinced them to sell me the new W10207783 kit at 50% off.
So I'm in the process of replacing the rods and unfortunately, once I got everything disassembled, the instructions say to inspect the screw threads in the base. Sure enough, all the loose spring movement wore away at one or two of the base screw threads, so I now have to order a replacement base. I just gave them the same explanation as to why I should get it at 50% off, and they agreed to grant me a courtesy discount on the base. Base part # is 8577373. They have 393 of them in stock as of 2/28/09. They wouldn't comp me on shipping at all, but I wanted it shipped 2-day since I have washing machine parts all sitting out and about.
I'm anticipating that once I get the new base, I'll be able to screw in the new springs and put everything back together within an hour or so and have a good-as-new washer. I'm a big do-it-yourselfer, so this work may not be for everyone. You could probably buy the parts discounted from Whirlpool then call a service repairman to follow the instructions and do the replacement for you. But because I did it myself, my total out of pocket, for the two parts at 50% off each plus tax and 2-day shipping on each order, was about $135 (~$70 for the springs and ~$65 for the base, including tax and shipping). If you're smart, you'll order both parts at the same time to economize on shipping. Or, maybe I'll try to scan and post the disassembly instructions so you can take it apart to see if your screw threads are stripped as well before you call to order only the replacement partsthat you truly need.
The whirlpoolparts.ca website is much more user friendly for the replacement purposes as I was able to find much more info there than on the US site. Here is the parts schematic for our unit:
http://www.whirlpoolparts.ca/parts/fspShowPageDetail.php?model=LTE5243DQ6&pageNo=11&bottom=true
and a service bulletin about the replacement of our suspension springs:
http://whirlpoolparts.ca/bulletins/attachments/bulletin_544/8178766C.pdf
Tools required for this since they are not listed in the instructions:
-philips screwdriver
--adjustable wrench pliers (needed for removing the suspension nuts, but also helpful for removing the hose clips which was tricky -- slide the hose clip up and off the hose, then with both hands, twist the hose to loosen it and get it off)
--1/2" wrench
--5/16" hex driver
--old towels, moving blanket or cloth drop-cloth to protect your floors
Good idea to vacuum out all the dust and other junk when you have the base out. Also, when you remove the counterbalance spring, use a paper towel to get a good grip and also to protect everything from getting greased up since it's got grease clumps there to prevent wearing away of the metal-on-metal. Be sure not to wipe it all off since it should remain there for that purpose. Also, I found it easier to unhook the bottom part of that counterbalance spring than the top -- the instruction just says just to unhook it.
One other note is to have an extra stabilizing hand help you when taking off the suspension nuts. Once you have 2 of them off, the whole assembly becomes very unstable. When taking those nuts off, don't worry if they fall behind the suspension screws, it's actually easier to have them do that, then after taking the assembly off the suspension springs, pull out the nuts. I'm sure I'll have a hard time lowering the assembly onto the new springs and getting the nuts started at the same time, so I figure an extra hand might very well come in handy when I get to this point too.
Good luck to all in fixing this annoying problem! Once I'm done with this mess, I'll report back to let you know how it all went when all was said and done...
Posted on Feb 28, 2009
SOURCE: 99 RX300 Engine code keeps coming up lean
I just had the same thing happen to my 99 RX300. I replaced the MAF sensor and cleaned the throttle body. We cleared the codes and check engine light came on again... with a knock sensor code. Had to replace knock sensors. Found some great info on how to do that here. http://us.lexusownersclub.com/forums/index.php?showtopic=41266&mode=threaded Car drives great now!
Posted on Jun 26, 2009
fixyathing
  • 341 Answers
SOURCE: LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
Posted on Aug 16, 2009
Ya hi my tv just leaned to the left yesterday and the tv will not go back on I bought it over a year ago I know the warranty is up by now can I get this fixed I ca,t afford a new one thanks ed
hi do you mean the stand ? if so you can replace the stand. or replace it with a back stand that connects using the wall fittings. Universal TV Stand eBay something like this.
Jun 27, 2017 | Televison & Video
Changed o2 sensor and trouble code p1131 keep coming up
What make vehicle do you have ? This code doesn't necessarily mean the sensor is bad ! That is why these thing's need to be tested before replacing , check with a scan tool that shows engine data . This code indicates a lean condition ( vacuum leak ) or a ( fuel problem ) P1131 Lack Of HO2S Switch Sensor Indicates Lean Fixed Lean O2 Is the sensor lying
Jun 07, 2015 | Cars & Trucks
2005 sportster custom with 13.5" shocks leans over too far on side stand
YOU CAN GET A LONGER KICKSTAND FROM EBAY OR DEALER, OR IF YOU ARE HANDY YOU CAN CUT IT AND WELD A PIECE IN THE MIDDLE TO MAKE IT LONGER
Jan 15, 2013 | Motorcycles
1998 dodge durango loud thumping noise front passenger tire looks crooked
A suspension part has come loose or is worn out. Check the top strut mounts under the hood. There may be a rubber plug to remove to see the top mounting plate. The three nuts around the perimeter of the strut plate are the mounting nuts, not the larger center nut-leave that one alone-it is for keeping the strut from coming apart.
If that mount is good, check for a broken coil spring around the strut.
Keep looking for the problem. If the tire leans out that bad, you should be able to spot the problem. Raise the wheel off the ground (recommend jack stands or blocks so it won't slip off the jack), grasp the wheel and shake it back and forth while watching for looseness or noise on the suspension parts connecting to the wheel hub at top and bottom- the upper and lower control arms and the strut connection.
Good luck.
Dec 31, 2012 | Cars & Trucks
Trying to assemble open box TV to stand. It appears 'guide stand' may be missing. Bust Buy and Samsung say call each other. Samsung LN32b550 Any videos to watch for assembly?
YOU CAN GET .PDF MANUALS AT SAMSUNG.COM.
I HAVE THE SAME TV. IT HAS EIGHT SCREWS THAT DON'T SEEM TO FIT IN THE HOLES, LEAVING THE TV WOBBLY AND LEANING FOREWARD.
ANY ONE ELSE HAVE THIS PROBLEM?
Jan 17, 2010 | Samsung LN32B550 32 in. LCD HDTV
I just purchased a 52 inch phillips tv and the stand that the tv sits on adds 2 inches which doesn't allow the tv to fit in my entertainment center. What can I do?? I need a shorter stand...
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
Nov 07, 2009 | Philips 52PFL3603D/27 52 in. LCD HDTV
Check engine light keeps coming on. Lean fuel
A lean code can be caused by several different things. The most common, if you are getting a lean code on BOTH banks, is a dirty Mass Airflow Sensor (MAF) Cleaning the MAF usually fixes it.
If not, it could be caused by anything from a crack in a vacuum line to a bad fuel pump. (Anything that could make the engine run lean.)
Oct 31, 2009 | 1997 Mercury Cougar XR7
Aug 16, 2009 | LG 32LG30 32 in. LCD HDTV
What does too lean stand for on a check engine light that comes on
there is lean and rich. This is the air/fuel mixture. Usually set by car computer if it is fuel injected. It the reading is not correct. It may be time for new o2 sensors.
Jun 02, 2009 | 2000 Toyota Corolla
Sony tv problem
You have a loose solder connection or two. If I knew the model number of the set, I could be more specific. I would expect the repair would run about a hundred dollars, so make sure the picture quality is great before going to the expense.
Aug 02, 2008 | Televison & Video
Televison & Video Logo
267 people viewed this question
Computer Repairing
Computer Repairing
