Furnace makes this loud noise when running. It doesn't always make the noise, but it seems to happen more often than not. Anyone know exactly what it is? Can I fix this myself? If this is something be
  • 3 Answers
Thats a problem for a professional trades man to look at
Posted on Nov 05, 2012
Krazytech
  • 725 Answers
SOURCE: Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Posted on Sep 11, 2007
  • 85 Answers
SOURCE: My Goodman GMS 90703BXA gas
Check the vacume in your inducer motor. Ensure it is pulling at least -9. If you don't have the equipment, you'll have to wait till it has a problem. Or, pay a tech to come out and service your system, with particular attention to the inducer fan..
Posted on Dec 08, 2008
rayname
  • 70 Answers
SOURCE: Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Posted on Jan 04, 2009
  • 659 Answers
SOURCE: Lennox G40UH-60D-135-14 Furnace will not ignite
Do you have an inducer on the unit (no access to the lennox model number tonight)? That is a motor that comes on shortly before your unit fires that blows the combustion gases up through the flu. Does this motor come on at all if you have one? If it does and the furnace will not light, then there is a device on the unit called a pressure switch. This switch has two wires to it and a small tube that leaves it and goes to the inducer housing. Remove the tube from the inducer and blow into and draw in air lightly or until you hear clicking noises. Replace the hose and try again. Sometimes the pressure switch gets stuck but can also go bad. If everything is coming on all the way up to ignition but the unit won't come on, then it's probably one of the limit switches that need to be reset. These are little disks about the size of a penny and have two wires going to it. In the middle is a small button that can be pushed to reset it. Some units have 2 to 3 and others have more. You have to use a flash light and look all in the unit around the burners and around the flu pipe looking for the limits. Once you have found them all and tried to reset the unit, then try to start it up again. Hope this helps.
Posted on Apr 04, 2009
  • 252 Answers
SOURCE: My Air Conditioner makes a loud buzzing noise now. It didn't do that before, now it makes so much noise I can't hear anything over it
Buzzing noise - contactor. maybe a bug got in the contacts or maybe the coil is bad but in any case if you replace the contactor the buzz will go away.
Posted on May 23, 2009
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
My furnace makes a loud noise on start up
What kindof sound? Is it a squelling kind of sound?
Jan 03, 2013 | Heating & Cooling
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
I have a new furnace with a humidifier. Both work fine. The trouble is, the water running through the hose to the drain makes a LOUD dripping noise when it runs into the drain. Is there some way to stop...
Not seeing exactly what you have. I am guessing...does the humidifier have a trap on it coming out of the furnace?. Is this some type of over flow from the humidifier? If so...
I would suggest running a 3/4' pvc pipe from the hose coming off of the humidifier and at a point lower than the humidifier install a trap...like what you see under your sink. Come out of the trap and run the solid 3/4" pvc to the drain and put a 90 elbow turned down into the drain. Buy installing a trap you should not hear the loud dripping noise.
I hope this helps you...Jim
Feb 20, 2011 | Heating & Cooling
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Jan 04, 2009 | Heating & Cooling
My Goodman GMS 90703BXA gas furnace started making higher then normal pitch sounds yesterday. The noise seems to come from the forced draft fan and it only happens in say 3 out of 10 starts so far. The fan...
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
