Question about Saws
Where can you find tradesman model 2124014 mitre saw parts
5 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: In need a new on/off switch for a Tradesman 10" Table Saw, Model 8030, Serial 000864
any 20 amp toggle switch will work.
Posted on Aug 03, 2009
SOURCE: need a owner manual for tradesman bench table saw model 8031
I believe I have the manual for the 8031 table saw. Are you still looking? Contact me at HollomannAFB@yahoo.com
Posted on Sep 12, 2009
I believe I have the manual. Are you still looking?
HansPP
  • 2510 Answers
SOURCE: I have a Tradesman 10" table saw Model BT2502W.
Bearings are made to be replaced and are a standard size. Either present the shaft size, the recess it fits into size and the width and any bearing dealer will supply you the required item. When you do buy a bearing ask for a 2RS bearing. That means that it has rubber seals on both side of the bearing. Or take the sample with you, even if it is in pieces. Also, the bearing number is usually stamped on the side of the outer race, something like 6201 or 6201 2RS.
Bearings can be difficult to remove, especially if they have fallen apart and the balls have come out. To get the inner race off a shaft, the easiest way is to grind the race on one spot almost to the shaft and then give it a whack with a hammer and it should crack in the ground face. The outer race can be levered out of the housing or if it is too tight, drill two 1/8" holes through the housing opposite each other so that you can knock the race out with a pin punch. Refitting the bearing (replace both of you can) - slide the new bearing onto the shaft after giving it a light rub with a fine abrasive material and giving it a light smear of thin oil, tap it down until it bottoms on its flange, when both bearings are on the shaft, press it into the housing and assemble the motor again - that's it.
Posted on Apr 14, 2011
I need a fence for an 8020 Tradesman Table Saw. Any ideas or anyone have one that costs less than buying a new saw? Please help.
Hello Kathryn
It is a Sears brand, so you can order the part from them.
This is a slightly newer model, (8031) but you can see they do all the parts
http://www.searspartsdirect.com/model-part/8031/3127/0744600/50020294/00001.html
There are also companies like this that may be able to help if you contact them.
Table Saw Parts
Jun 12, 2016 | Saws
I need a parts diagram for a mastercraft metal hand mitre saw?
Spares and parts diagrams here for all Mastercraft Mitre Saws.
Craftsman Miter Saw Parts
Dec 30, 2015 | Saws
How do I get an owner's manual for an Ace 10" compound mitering saw model #2124014
try contacting the manufacturer on line, they may have one you can download.
Hope this helps.
Feb 02, 2015 | Saws
Where do I get a bushing for the guard on a 10 inch mcculloch mitre saw
You probably mean a Milwaukee mitre saw. McCulloch does not make a mitre saw. Go to eReplacementparts.com and enter your make and model number. If they don't have it, its probably not available anywhere. You'll have to go to a machine shop instead. Look it the yellow pages for "Machine Shop".
Oct 04, 2014 | Saws
Do you have any info on the craftsman model 137285850 mitre saw. owners manual? problem with mitre guage for angles, was removed not sure where it installs on base
You can see a breakdown of this that might help you go to
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137285850/0247/0744300?pathTaken=&prst=0&shdMod=137285850
Hope this helps!
Feb 20, 2011 | Garden
I have a tradesman 10" miter saw model 2124014 and I can't get the blade off. Does the bolt turn clockwise or counter clockwise to loosen.
Miter saws usually are left threaded...so you turn it clockwise to loosen. There should be a lock near the handle so you can lock the blade to loosen.
Sep 26, 2010 | Garden
Mastercraft Maximum Compound Mitre Saw
built by canadain tire company their customer service number is 1-866-746-7287 they should be able to get u replacement part and or advise who in ur area can
Jan 25, 2010 | Saws
Need a owner manual for tradesman bench table saw model 8031
Mar 18, 2009 | Saws
Need a detailed schematic for handle of a hitachi C10FC mitre saw
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
Dec 30, 2008 | Hitachi C10FCE2 10" Compound Miter Saw
Saws Logo
133 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
