Question about Whirlpool GS460 Gas Kitchen Range
Gas range thermastat
I have model # sf3020ekq3 and would like to know where I find the thermastat on the range . And what the part # is for this model thermastat.
Manufacturer Number W10159016
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-5-655221-/Whirlpool-Oven-self-cleaning-problem-SF3020EKQ3
Posted on Nov 05, 2012
Set thermastat to 350 shuts off at 425
Get a gas fitter to do it mate safer bet
Aug 07, 2012 | Imperial IFS40 Deep Fryer
My gas range model number JGS968SOH33SS will not heat. Thermastat stays at 100 degrees. The gas burners and broiler work. Repair man says it can be a problem in the control panel. Any other things that it...
Hello, welcome to FixYa.
Based on your description, I`d suggest the hot surface ignitor for the bake burner is likely the problem. Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined.
It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
since your boiler has the same ignitor ( some do some don't, only a model number would confirm or dismiss this...thankfully you provided yours ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
You can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake & broil ignitor.
I would still double check with your model number with the part`s professional`s.
Hope that help`s. It is very unlikely to be the control panel/timer contrary to what your repairman has said...in my opinion. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
Regards,
Macmarkus :)
May 21, 2011 | GE Kitchen Ranges
Need to know how to replace thermostat
Hi: You'll first want to Drain your Radiator take your radiator cap off so when drain it the coolant will drain freely.Then Drain your raditor you'll find a Drain Tee outlet on the inside bottom of your radiator. And catch the Coolant in a Drain Pan. Standing in Front of your Vehicle you'll see a Hose connected to your Radiator(UPPER RADIATOR HOSE) take your Hand and follow it down to your Engine until you locat a Hose Clamp Remove the hose clamp and work off the top Radiator Hose.Where you removed the hose theres a Dome Shaped Metal Housing,with 2 bolts in it. Take those 2-Bolts out and Remove the Dome Thermastat Housing,Under it You'll Find your Thermostat it shuold come out with a little Resistance. Once its out, Clean Up The Thermastat Dome of any Gasket still left on it, and clean where you remove the Thermastat Surface.To put back just Reverse the Removal Be-sure your Thermastat is put in right and not up side down.Then get some Gasket Sealer Put a Little on the Thermastat Housing where gasket goes and some on the Enging surface and Install your New Thermastat,Be careful when Tightening the 2-Bolts on The Housing. not to Over tighten them.The torque Specs on the 2 bolts range between 10- 15 Foot pounds.You don't want to Strip,
After you get your New Thermastat in and your Radiator Hose on and Clamped.Make Sure you have closed the Drain outlet. then fill with coolant,if your coolant is old i recommend putting new coolant in. I hope this helps You.I;m Sure it Will, But please let me Know through FIXYA by Voting and a Testamony.This way I'll know that my solution was Helpful. Thanks From d_hubbs
Jun 06, 2010 | 1997 Chevrolet Monte Carlo
My Magic Chef, model 3868VVD range oven will not heat above 250 degrees Fahrenheit. I replaced oven (not broiler) element a couple of years ago and it still looks fine. Is it perhaps the thermostat?
Yes you are correct, you have a probe inside the oven that sticks out, this is what measures temperature. Most models this sensor probe connects to the board and some models the oven thermastat has the sensor probe connected to it..
whites appliance repair
Aug 24, 2009 | Kitchen Ranges
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
Oven running very hot and burning everything !
replace the thermastat or oven sensor it it does not have a thermastat with out a model can not give you a part number
Apr 17, 2008 | Kitchen Ranges
XL44 Self Cleaning Gas Range
your set up foir the wrong type of gas
you probaly have a natural gas oven
'and your using propane
Dec 16, 2007 | GE JGBP24 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
