Question about Estate TT18TKXKQ Top Freezer Refrigerator
After thawing the freezer , everything worked fine for about a week now It won't turn on at all.
It started with the fridge nor cooling. Fixed that by thawing the freezer coil which was completely frozen. Then everything worked ok for about a week. Then the freezer won't freeze and the fridge won't cool . I turned the fridge off and on and now it won't turn on at all.
    Top Expert:
  • Estate Master
  • 9,472 Answers
Is the compressor kicking on at all?
Posted on Nov 06, 2012
4 Suggested Answers
davidpsr
  • 222 Answers
SOURCE: Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Posted on Aug 29, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator bottom will not cool.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 09, 2010
heatman101
  • 43501 Answers
SOURCE: Not cooling in refrig area & low cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdsjd
Posted on Sep 29, 2010
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer fine- fridge temp is 51 degrees
I got the same problem. For some reason in the freezer part on the back wall there is a condensor and it keeps on getting all iced up and then there is not enough air pressure for the fan to circulate cold air to you fridge part. I took mine all apart used a hair dryer to thaw out everything which took out about 1 gallon of water from the hose in the bottom back of fridge. It fixed the problem for about 4 days and then froze up again, There must be some type of tempature sensor or automatic defroster not working like it shoud.Does anybody know? Help me too?
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Jan 11, 2009 | Dometic RM2852 Refrigerator
Estate TT18TKXKQ Top Freezer Refrigerator Logo
251 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
