Question about Drills
My Altocraft 18 volt battery wont take a charge
  • 10 Answers
SOURCE: dewalt battery 18 volt
Are you sure it is the battery and not a charger fault, is the charger warm after it's beeen plugged in for a while?
HHM Service Centre
Posted on Dec 21, 2007
muttandjeff
  • 359 Answers
SOURCE: Dewalt 18 volt battery life
run all the way down before charging as far as possible then charge see if is any better
Posted on Dec 03, 2008
muttandjeff
  • 359 Answers
SOURCE: Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Posted on Jan 12, 2009
  • 126 Answers
SOURCE: 18 volt ryobi batteries wont hold charge
NiCads stop taking a charge because microscopic crystals build between the individual battery cells (inside the pack) and the leads between them. here is what i have done for my craftsmen NiCad 18 volt batteries to get them to once again hold a charge:
you'll need ~2 to 3 times the voltage that you are using. for instance, if you've got a 14v drill battery that has stopped working, then you'll need 28-42 volts, 18v will need 36-54 volts. i have found 3 car (or motorcycle or lawn tractor) batteries work fine. so i have 2 motorcycle batteries and 1 tractor battery.
i hook these car/motorcycle/tractor batteries up in series. positive from one batt to the negative of the next and so on until i have one positive lead not connected and one negative lead not connected.
something like this: --(batt)+_--(batt)+_--(batt)+
then with safety glasses on i touch the positive lead from the motorcycle battery to the positive tab of the NiCad drill battery with one hand and the negative lead of the tractor battery to the negative tab of the NiCad drill battery (at the same time) and count to 3. i remove and wait a few seconds (5-7) and repeat 2 more times.
once the last ZAP is done, place the NiCad drill battery into the charger and see if the charge light illuminates. if it does, then you have just saved a battery from the land fill and some $$ from your pocket. if it doesn't, then try to repeat it once more, but no more after that.
some word of caution. do not let the the + & - leads of the car/motorcycle/tractor batteries touch each other. that's 36 volts you've got there and will spark/explode.
also, if during the zapping of the dead NiCad battery you hear a "pop", one NiCad cell inside the battery pack has given up the ghost and now the battery is trash for sure. take it to radio shack for recycling. do NOT attempt to zap it again.
use at least 14-16 guage wire (or larger which is a smaller number) to connect the batteries in series and also to zap the NiCad drill batteries.
one final note: do NOT use this method on Lithium Ion batteries. it will not work and may cause injury!!!
good luck.
Posted on Jan 31, 2009
frankzen
  • 19 Answers
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Posted on Apr 04, 2009
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Wont take charge
How old is it?
Are you trying to charge it while it is hot?
2 or more years old ... it is done
Hot? Hot batteries will not charge.
Oct 15, 2009 | CRL 18 Volt Battery Cartridge for LD147...
How to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Oct 13, 2009 | Drills
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18 volt battery wont charge
no its best just to replace them
Dec 27, 2008 | Hand Tools
Drills Logo
145 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
