End of cycle
Stay on 1 minute for 35 min?????
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do we set the clock on Sharp logicook R-7N76?
Press stop/clear pad to remove 88:88 from the display.
Press auto start once for 12 hour clock and twice for 24 hour clock.
Enter hours first using 10 minute and 1 minute pad (i.e. for 12:00 - press 10 min button once and 1 minute button twice)
Press auto start.
Enter minutes as before using 10 min pad and 1 minute pad (i.e. for 35 mins press 10 min button 3 times and 1 min button 5 times)
Press auto start.
Jan 22, 2010 | Sharp Office Equipment & Supplies
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
