Question about Cell Phones
M using 1GB micro sd-c01G taiwan n lost my password n explorer doesnt work
SOURCE: unlock 1 GB micro sd memory card of Kingston Made
i forgot my password...pls help me unlocked. i have got nokia 6233with 1gb micro sd. i tried to give password for the sd card. but it doesnt worked. i tried it many times. one day my phone automatically got switched off. when i switched on the phone the sd card was locked and it was asking for the password..i tried many passwords but not able to open it.. what shall i do npw . is there any software or something to open the sd card.....anyone please help me.......Solve This!
I have the same problem
Posted on Nov 20, 2008
Bajanguru
  • 7752 Answers
SOURCE: micro sd password onlock
take it to a mobile center and ahve them use the JAF box to master reset the code or remove it permanently for you.
Posted on Aug 16, 2008
prerit_777
  • 214 Answers
SOURCE: Samsung J700 memory card problem
it is compatiable for only 1 gb card
Posted on Sep 02, 2009
SOURCE: i forgot the password of micro sd card
256MB micro memory card was locked.. password forgot. how to open card
Posted on Sep 22, 2009
  • 186 Answers
SOURCE: Phone Nokia 2700 Classic remove
Hi ,
Follow the following steps to remove the password check in
memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
It has worked for the following user . pls click here to view
For any quires write back to me .If yo are satisfied with my answer please vote for me(4ups) . thanks in advance
Posted on Nov 27, 2010
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
My memory card micro SD IOBE '0710 is loked with password and i lost my passord any solusation
my memory card micro SD is locked with password and i lost my password & it is not recognising
Mar 06, 2010 | SanDisk 1GB microSD Memory Card
that unit only reads a 1gb of memory card
Aug 23, 2009 | Samsung J700 Cellular Phone
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Unlock micro sd 1gb
hi,
first try to put the same code/password as of your old phone if it will work then good
otherwise
try to unlock with the new phone code.
if none of them work
then format the card from pc and format using FAT not FAT 32.
this will solve your problem.
Mar 24, 2009 | Nokia N95 Cellular Phone
Formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Dec 31, 2008 | Electronics - Others
Unlock 1 GB micro sd memory card of Kingston Made
Aug 23, 2008 | Nokia 6151 Cellular Phone
hi this is rahul , i'm having 1 GB micro sd memory card for my mobile nokia 7210supernova ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i have a sandisk sd card and i am not able to access it as i forgot the password..........pls help me .......neither i can format it nor using pc suite i can solve the problum..........pls help me!
Aug 10, 2008 | Lands Phones
Cell Phones Logo
191 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
