Washing machine is now noisy when it spins it is a swan essentials
  • june rowland Nov 07, 2012
    it washes fine not noisy just a bit loud when spinning we found 2 white plastic tubes at bac of it one end is round and other end is oblong dont no if these av come of somewhere
    Sergeant:
  • 389 Answers
If you put your hand inside the drum and rotate the drum by hand does it rumble if it does it is your drum bearings
Posted on Nov 07, 2012
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
  • 209 Answers
SOURCE: wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Posted on Sep 25, 2007
SOURCE: noisy spinner on my service washing machine 3yrs old
sounds like the main bearings need replacing, get an estimate, it may be time to replace your machine
Posted on Nov 05, 2007
COXY
  • 76 Answers
SOURCE: VERY NOISY WASHING MACHINE
The bearings are going, repair cost aroung the 100 pound mark
Posted on Nov 18, 2007
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
Swan essentials washing machine wont start pause play button just starts flashing after a minute or so
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them
from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Washing Machines
User manual sw2051w
The SWAN (SWAN Laundry only) Help Line: 01189 252545 Monday-Thursday (9:00 AM-5:30 PM) Friday(9:00 AM-4:15 PM) You will need to tell them The Make: SWAN The Model:SW2051W
Good Luck! Swan is only warrantied in U.K. and Ireland!
Apr 23, 2016 | Sourcing Map Water Liquid Level Sensor for...
Control button is loose on my swan essential SW2010W. Just keeps on turning and not clicking on the required setting
Pull the dial off, there might be a couple screws behind it, tighten them and see if that helps.. also while the dial is off check for any broken pieces
Nov 17, 2014 | Washing Machines
Swan Essentials SW2010W The middle button will not go off and the washing machine will not work
SW2010W Hi the on / off button has pushed right in and wont come up can you help please ?
Sep 16, 2011 | Washing Machines
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
