Question about Maytag Dryers
Part number for belt Maytag DE210 electric dryer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is the belt you requested.
Posted on Nov 06, 2012
Nitrotrike
  • 589 Answers
SOURCE: Open Dryer to replace belt
Here's a pretty good tutorial on disassembly. Just scroll down to the Maytag section:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Posted on Jan 11, 2008
captaynkyrk
  • 170 Answers
SOURCE: dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Posted on Nov 01, 2008
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
  • 10865 Answers
SOURCE: replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Posted on Apr 07, 2009
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Maytag Dryer DE210 wont start
This fuse is often mounted within the exhaust duct in the back panel. It is about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced.
Good Luck and have a nice day.
Jul 02, 2010 | Maytag Dryers
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
What part number is the drum belt for a maytag electric dryer model # DE 50 Serio no. 997874 KF?
part number and demensions Dryer drum belt - Length is 87-3/4" Width is 1/4".
Part Number: AP3865318 made by FRIGIDAIRE does not come up as maytag.
Oct 09, 2009 | Dryers
MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE WHAT COULD THAT BE??
Nased on your description, MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE, I have provided some links that may help you diagnose your issue.
1. Drum Belt
2. Drum Belt and Roller kit
3. Parts breakdown and disassembly diagram
4. Belt installation diagram
You will need to provide the model number off the product ID tag located on your dryer to access the links information. Click link number 1 to begin.
1. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i529597&PartID=529597
2. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i587636&PartID=587636
3. http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
4. http://www.affordableappliance.com/Tips/beltdiagrams.htm
Aug 24, 2009 | Dryers
Dryers Logo
197 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
