I turn the computer on and the monitor shows a msg saying saving power mode on
When you cannot get a computer out of "power save mode", the culprit usually is an empty battery on the motherboard of your computer.
Typically, this happens on a computer which is a few years old, since its batteries will have run out after such a long time.
The motherboard battery is used to store various settings, such as date and time, when the mains power is off. When your computer detects an empty battery, it goes into a low-power mode.
The computer will then display as message, like "Power save mode - press any key on keyboard or move mouse". However, in certain circumstances, doing so does nothing.
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Posted on Nov 05, 2012
Fix-4U
  • 293 Answers
SOURCE: my LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Posted on Oct 13, 2008
  • 38 Answers
SOURCE: "analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Posted on Oct 01, 2007
  • 624 Answers
SOURCE: Monitor
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t139319-monitor
Posted on Mar 25, 2007
pravinbhavsa
  • 348 Answers
SOURCE: Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Posted on Oct 29, 2008
SOURCE: LG LCD monitor goes in power saving mode
press fn + F5 buttons, screen will appear
Posted on Dec 21, 2008
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
447 people viewed this question
David Payne
David Payne
