Question about Rockford Fosgate P3001 Car Audio Amplifier
Problem with the bass controller.
I was changing my alpine amplifier to rocford power amplifier today. then when i was done i put some music on. But the blue light on the bass controller was weak. and i just have a little bass. I have used that rockford amplifier before. please tell me why the blue light is weak.
  • 7 more comments
  • killadupp Jan 05, 2009
    i don't ground through the battery, just from the car chassis. but shouldnt the protect light up if i hade bad grounding?
    so the protection light should light up when i have GOOD ground?
    ok. but i'am using the same ground spot and same ground cable on the rockford ampilifer that i used on the alpine amplifier. so why does the blue light on my bass remote controller light up so weak?
    ok, but when the blue light is lighting up weak, i don't have any bass almost. I can hear the bass, but that is little. So something is wrong, but where?
    you mean in the bass remote controller or the amplifier?
    ok, its weird. i used the rockford amplifier for some days ago. then i switched to a alpine amplifier because the rockford took all my battery. then i buyed a new battery yesterday. and switched out the alpine again to day. and the rocford does'nt work. i hope nothing is wrong with the amplifier.
    but im going to bed now. im gonna check the amplifier tomorrow. please keep answering me tomorrow. thanks :)
    i was trying to get the amplifier to work properly today. but it's look like it doe'nt get enough power. What can be the answer to where it's leaking power?
  • killadupp Jan 06, 2009
    ok. that sucks.
    President:
  • 1,990 Answers
Sounds a lot like you don't have it Grounded Enough. Did you run a Ground all the way to the Battery?
Posted on Jan 05, 2009
  • 5 more comments
  • Travis Humphries
    Travis Humphries Jan 05, 2009
    It will if it is Grounded good. I am running 3 5oo watt Punch Amp's in my Truck and have had no Problem's once Grounded to the Battery.
  • Travis Humphries
    For it to Operate Properly. If there is a Problem Internally it will light and Protect the Circuit.
  • Travis Humphries
    Could just be that the Bulb is going out. I got one like that right now.
  • Travis Humphries
    There are Power Diodes on the Inside Board. Check these for Leakage. There will be Mercury looking Stuff coming out of the tops. If so that is your Problem. You can get these at Radio Shack and Repair it.
  • Travis Humphries
    Inside the Amplifier.
  • Travis Humphries
    No Problem!
  • Travis Humphries
    Travis Humphries Jan 06, 2009
    Ok- I have done some Research on this and the Only Solution is to Get it Repaired at an Authorized Repair Center.
Which are the best speakers i should use with my sony amp 222
Rockford is great for bass and your two way speakers. Alpine still controls the three way speakers that I would suggest for wanting the strong vocals with less bass. Too much bass bad so I would ignore most input from "audio" guys. They always over build the bass side, balance is the key.
Jan 22, 2013 | Sony XM-222 Car Audio Amplifier
Watts
The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
Details:
  • 150 watts RMS x 1 at 4 ohms
  • 300 watts RMS x 1 at 2 ohms
  • MOSFET power supply and output stage
  • STAR Topology for cleaner sound
  • Bass Engine® features:
    • low-pass digital crossover, 30-200 Hz, 24 dB/octave
    • variable subsonic filter (15-50 Hz in 5 Hz steps)
    • parametric EQ variable from 30-160 Hz
    • Bass Compensator enhances low-end definition
  • top-mounted digital control center with cover
  • time correction 0-10 milliseconds in 0.5ms steps
  • phase correction 0-180° selectable
  • digital readout
  • detachable front cover
  • blue power LED
  • delayed turn-on
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • speaker- and preamp-level inputs
  • gold-plated terminals
  • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
  • 1-year warranty
May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
Alpine amplifiers fade in and out durring high volume bass hits
main problem i think you are having is your loosing power when it kicks a note.. get a power cap! power caps feed your amps constant power! this will solve your problem :)
Jan 06, 2009 | Alpine MRP-M450 Car Audio Amplifier
Voltage drop
You're drawing a ton of power from the car's electrical system. Get a stiffening capacitor and put it in on the amp's main power cable. If you're draining the car that badly, make sure to get at least a 1 farad cap, bigger if you can, and until you do, turn the gain down and don't run so much bass - you'll kill your battery in the meantime.
Jul 29, 2008 | Alpine MRD-M1000 Car Audio Amplifier
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Rockford Fosgate P3001 Car Audio Amplifier Logo
144 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
