Question about Sharp EL-2196BL Calculator
The display is not working on my Sharp EL-2196BL, it is very faint, am I missing an easy fix?
I noticed a week ago that the display was lighter, but today you can't see the display at all, does the battery have anything to do with this?
3 Suggested Answers
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
jyackle5
  • 8197 Answers
SOURCE: HOW DO I SET THE TAX
You can get the manual on link below it will tell you how to set the tax.
http://dl.owneriq.net/2/2f5de9b8-0a25-e1f4-d9c2-132001ba18e5.pdf
Good luck and please rate 4 thumbs for the free answer
Posted on Mar 14, 2010
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
We have a SHARP EL-2196BL printing calculator, but no user manual. We can't get it to print the answer when we are adding. It shows on the screen, but not the paper. Also, it just keeps adding up...
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2196BL.pdf
Feb 26, 2011 | Sharp EL-2196BL Calculator
HOW DO I SET THE TAX ON THE SHARP EL-2196BL?
Mar 12, 2010 | Sharp EL-2196BL Calculator
Want to replace ink roller on Sharp EL-2196BL -
http://www.gorillapaper.com/univ-cal-spool-br-12-per-box.html
Universal Calculator Spool 12pk
Thank you
Oct 08, 2009 | Sharp EL-2196BL Calculator
How do I replace the printer paper in my sharp EL-1192BL calculator
Feed the paper into a VERY thin slot on the back side of the calculator. This thin slot is below the removable clear plastic paper guide and is very inconspicuous.
Apr 10, 2008 | Sharp EL-2196BL Calculator
Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Mar 10, 2008 | Sharp EL-2196BL Calculator
Set tax
To set your tax rate:
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Mar 03, 2008 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
