Solution for code F6 on 18000 btu ac unit westinghouse
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Hi i have a Maytag 12000 btu Window ac unit that
I had a similar problem with my AC last week. These newer capacitors no longer have PCBs in them. The stuff they use now just ain't as good. As a result their are more capacitor failures tan ever. I would check that. If the cap looks swolen its probably bad.6f0f1c5.jpg52ae98e.jpgYou should also try and lubricate the motor. Use HVAC oil 106f87c.jpg$2 at Ace hardware store.
You gonna have to slide out the unit a little to get to the motor. Have rags ready.
Posted on Jun 18, 2010
hvac1960
  • 2133 Answers
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
Posted on Dec 13, 2010
  • 884 Answers
SOURCE: hyundai 24000'btu ac outdoor unit con moter wirig what runing'starting'comon
Three pins Common is neutral. Start is start from relay, Run is run from relay Usually Common at top, Start bottom left, Run bottom right but check a manual if you can find one.
Posted on May 18, 2012
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
What is the wattage of a 6000 btu ac unit
WATTAGE VARIES , START UP 3X WHAT RUN IS BUT A 20 AMP CIRCUIT SHOULD HANDLE FINE , CODE RECOMMENDS A LONE CIRCUIT FOR AC UNITS ANYWAY , BUT IF YOU WANT A GUESS AROUND 12 AMPS X 120 VOLTS =1440 WATTS GUESS MANY VARIABLES .
Aug 17, 2014 | Heating & Cooling
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
I need an idea of square foot coverage
There are more factors than sq ft. You have to factor in window surface and R factor of insulation.
Aug 18, 2009 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
