What's your problem?TO MAKE MY NEW PASSWORD
FOR OPENING THE COMPUTER ' PASSWORD' FOR OPENING THE SPIDER SOLITARIE
  • 7,627 Answers
Im confused? Password for login? The microsoft games do not need a password> In all programs click on games and open.
Posted on Nov 05, 2012
Unlocking my computer
Assuming you mean the 'BIOS Password', turn off & UNPLUG the power cable. Then open the case, find the little silver battery 'coin cell' battery (type CR2032) = on the moherboard, make a note which way round it is & and remove it for a coiple of miniutes.
After putting it back in, when you next power up, you will have to eneter the current time & date into the BIOS..
Nov 12, 2012 | E-Machines eMachines Desktop PC
I locked my computer and i forgot the password
Can't use old laptop computer Dell Precision M60; Windows XP password lost-no way to open to gain access to computer. Would like to reset password.
Boot computer Into safe mode. Open command prompt type this.
Net user *
PRESS ENTER
net user (your user name) *
ENTER NEW PASSWORD
ENTER NEW PASSWORD AGAIN
DONE
Apr 28, 2012 | Dell Precision M60 Notebook
I seem to always get a static sound out of my Line 6 Spider Iii below 9 o'clock on the volume knob. Not only is it staticy, but the volume jumps all around and goes from whisper quite 1 second to house...
It sounds like you have a dirty pot (the volume control). Unfortunately the only way to clean the pot is to open the amp up and try to spray some Servisol Super 10 in through the small opening in the pot case.
WARNING: Tube amps contain lethal voltages even when unplugged! If you are not an experienced service engineer then take it to someone who is! It is a pretty common task in guitar amps so shouldn't cost too much.
Sep 10, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
Forget password
To change password of an user account, we need to go to User Accounts panel in Control Panel, choose the user account, click on 'Change my password' link, type current password once and new password twice. Too lengthy a process isn't it? Here is handy tip to change Win XP passwords in DOS mode and believe me, it takes less than 5 seconds!! Let me share the hack with you all!
net-user-pwd.gif Steps to change password
  1. Click on 'Start' and then on 'Run...'.
  2. Type 'cmd' (opens up the command prompt).
  3. Now type net user * (do not omit the spaces)
  4. You will get a prompt like .. Type a password for the user:
  5. Type the desired password and press Enter key. Also note that you wont see *****s as you type but don't worry.
  6. You will again get a prompt like .. Retype the password to confirm:
  7. Retype the password and press Enter key. Here too you wont see *****s as you type but don't worry.
Thats it!!! Oh no .. wait .. Did it cost you more than 5 secs? OK Try this ..
Another Solution
Computer passwords are like locks on doors - they keep honest people honest. If someone wishes to gain access to your laptop or computer, a simple login password will not stop them. Most computer users do not realize how simple it is to access the login password for a computer, and end up leaving vulnerable data on their computer, unencrypted and easy to access.
Are you curious how easy it is for someone to gain access to your computer? If so, read on to see the technique one might use to figure out your computer password.
Windows
Windows is still the most popular operating system, and the method used to discover the login password is the easiest. The program used is called Ophcrack, and it is free. Ophcrack is based on Slackware, and uses rainbow tables to solve passwords up to 14 characters in length. The time required to solve a password? Generally 10 seconds. The expertise needed? None.
3237188885_1527db4c72_m.jpgSimply download the Ophcrack ISO and burn it to a CD (or load it onto a USB drive via UNetbootin). Insert the CD into a machine you would like to gain access to, then press and hold the power button until the computer shuts down. Turn the computer back on and enter BIOS at startup. Change the boot sequence to CD before HDD, then save and exit.
The computer will restart and Ophcrack will be loaded. Sit back and watch as it does all the work for your. Write down the password it gives you, remove the disc, restart the computer, and log in as if it were you own machine.
Mac
The second most popular operating system, OS X is no safer when it comes to password cracking then Windows.
The easiest method would be to use Ophcrack on this, also, as it works with Mac and Linux in addition to Windows. However, there are other methods that can be used, as demonstrated below.
If the Mac runs OS X 10.4, then you only need the installation CD. Insert it into the computer, reboot. When it starts up, select UTILITIES > RESET PASSWORD. Choose a new password and then use that to log in.
If the Mac runs OS X 10.5, restart the computer and press COMMAND + S. When at the prompt, type:
fsck -fy
mount -uw /
launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist
dscl . -passwd /Users/UserName newpassword
That's it. Now that the password is reset, you can login.
Linux
Finally, there is Linux, an operating system quickly gaining popularity in mainstream, but not so common you're likely to come across it. Though Mac and Linux are both based on Unix, it is easier to change the password in Linux than it is OS X.
To change the password, turn on the computer and press the ESC key when GRUB appears. Scroll down and highlight 'Recovery Mode' and press the 'B' key; this will cause you to enter 'Single User Mode'.
You're now at the prompt, and logged in as 'root' by default. Type 'passwd' and then choose a new password. This will change the root password to whatever you enter. If you're interested in only gaining access to a single account on the system, however, then type 'passwd username' replacing 'username' with the login name for the account you would like to alter the password for.
Conclusion
There you have it - that is how simple it is for someone to hack your password. It requires no technical skills, no laborious tasks, only simple words or programs. The moral of the story? Encrypt your data to keep it safe. Don't use only a password, but actually encryption, such as Blowfish or AES-128. There are a number of programs that can do this - TrueCrypt for Windows, or the native encryption found on Ubuntu, creating a disk image in Mac, etc.
Aug 09, 2011 | Computers & Internet
I'm trying to connect a new laptop to my router. I don't know the security key. How do I find this? And how do I get this to work??
In which computer you have inter net in that computer please click on START and click on RUN in that box enter CMD. You will get command mode. In that command mode type this command. 'ipconfig'. You ll get the ip address and gate way. Please close all of the window and open internet explorer in that same computer and enter the gateway ip address in that address bar. it will open new webpage. then enter the username and password of the router. in that window you can find the wireless settings and security key. If you don't know the username and the password of the router please open this link and find the name of your router in this page and take the username and the password. The Link is : http://www.phenoelit-us.org/dpl/dpl.html
Aug 02, 2011 | Computers & Internet
Wep key invalid ? but correct wep key?
Have a 52' Panasonic projection HDTV & a spider
you just open your tv by using the tools needed match on the screws.if you fear to open your tv you go to the nearest technicans over you.
Jun 11, 2011 | Panasonic Televison & Video
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
