Question about Canon imageRUNNER 210S Copier
E 100 switch main power off and on. E 100
    Problem Solver:
  • 21 Answers
Laser unit or cable.
Posted on Dec 18, 2013
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
Here's the info on the transfer switch. The
What do you mean by "there's no power to the disconnect switch"?
Is it the feeder from the mains or from emergency generator?
If it is the input from mains and you don't have voltage on it, this should make the generator to start, if automatic start is selected and thus give voltage to the other feeder (emergency), the switch goes on and the consumers have power.
If you have power on your mains feeder, you don't need voltage on your "emergency" feeder. Then the consumers should be supplied by your mains contactor.
Jul 21, 2010 | Generac 100 Amp 120/240-Volt Transfer...
I need to know exactly what voltage of power
Dear,
Power Supply 100–240VAC, 50–60Hz
Power Consumption 232W max.
Its mean its a switching supply that can support as low as 100 and more as 240VAC
If there is a problem with supply and you want to attach a fix one then Check the MAINS at your area. If it is 110VAC then get it and if its 220VAC then use the supply for this kind of support
good luck..........
Jan 30, 2010 | Televison & Video
My polo main headlights do not work but my full beam does work
Hi, the main headlights work through a separate fuse from the full beam. If all the fuses are fine the problem might be that the globes has blown on the vehicle. To make 100% sure that it is the globes, see if you get power to the headlights when the main lights are switched on.
Nov 24, 2009 | 2004 Volkswagen Golf
Have a 100 amp integrated 12 circuit load center. The top coil burnt bad. The main power is three phase four wire in the distribution panel but we only supplied emergency power to lighting circuits and...
Yes, if ANY load circuits on the third phase was ALSO connected to the transfer panel circuits, a sneak path would allow the third phase from the power company to backfeed this [panel causing damage.
Sep 26, 2009 | Generac Guardian 100 Amp Transfer Switch...
Is there a main power reset button. my tv just
tv's haven't used reset switches since the 70's if you have no power something inside must be blown, without knowing what model you have it could be 100 things. but i'm sure it isn;t a switch, they almost never go bad. people always think it's the power switch or the cord, because it's the only parts they know, they don't realize what goes on for your tv to turn on, it could be alot of failures. you need a repairman.
Sep 15, 2009 | Televison & Video
Canon imageRUNNER 210S Copier Logo
old marine
old marine
