Question about Maytag 24 in. MDBH940AWS Built-in Dishwasher
Noise at end of drain cycle.
After several years of completely trouble free use the dishwasher has started making a loud and what sounds like a serious noise right towards the end of the drain cycle (approximately 2 minutes left on drain). The noise can best be described as something hard rubbing against a large gearwheel turning at speed. Since there are also splashing noises as well this is the best I can do right now. The noise is consistent with each cycle. I have looked inside the dishwasher but I can't see anything loose or broken anywhere. Nor can I see any bones or other hard food that might be the cause. The dishes are still being cleaned but I am concerned that something will break if this noise persists. (For all I know something is already broken.) I have some skill as a handyman and I have in the past replaced the entire motor on a GE dishwasher. My problem is that with this machine I don't really know where to start troubleshooting so any hints or tips will be greatly appreciated. Thank you, Rich
  • Anonymous Jan 04, 2009
    I believe my dishwasher is making the same noise. Sounds like gears slipping. Noise is not constant, but seems to happen as cycles change? Not sure.
  • 247 Answers
There aren't really all that many energetically moving parts inside a dishwasher - fewer still that are active during the drain cycle. Follow the drain hose into the machine, and you should come upon the drain pump. Have a look inside that, and in the hose that runs between it and the sump it drains. My best guess is that some piece of buoyant debris is sitting in that line, and, as the water level drops, is lowered into the pump impellor. Usual warnings about disconnecting power before putting your hands inside the machine apply - and be aware that you're likely to find a bit of dirty water sitting around in the pump. A.
Posted on May 21, 2007
Hi I have a bosch classix maxi been great for the last couple of years but it has failed for the first time yesterday. The dishwasher did not start it just kept making a groaning noise and would not start...
Completely unplug the dishwasher and leave disconnected for at least 10 mins.
Also be sure to check the drain pipe is not kinked or obstructed and that the filter is also clean and empty
May 04, 2011 | Bosch 24 in. SGS43C12 Classixx...
After completing the wash & rinse cycle the dishwasher won't drain
In my experience, in this case it is likely that your dishwasher is not draining at any time throughout the wash or rinse cycles. The overflow float is preventing your machine from overflowing.
Here are a few things to check:
  1. If this is a new install, or the disposal has just been replaced, make sure the plug in the disposal has been removed. The nipple where the drain line from your dishwasher attaches has a plug on the inner wall of the grind chamber from the factory.
  2. Listen to the sound of the drain motor by starting a cycle and then canceling after a few seconds. Make sure the drain pump is actually running and not just making a loud humming noise as if it is seized, or something is binding it.
  3. Finally, check your drain line from your dishwasher to your disposal (most common drain connection), or where ever your drain line connects. Slight kinks and sharp bends have a tendancy to collect debris and create a plug-up. If this is the case, simply take the drain line loose from the drain pump and from the disposal and take it an outside water faucet. Place the disposal end against the faucet and slowly turn on the water. It will usually blow the plug right out.
Apr 16, 2011 | Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Maytag 24 in. MDBH940AWS Built-in Dishwasher Logo
199 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
