Question about GPS
Orwak 3600 Circuit Diagram - GPS
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
Assembly and/or parts manual for Body Solid EXM-3600 and EXM-1950
The EXM 1950S Is the G4I and EXM 3600 beats the heck out me!!! The best suggestion is to call Body-Solid Directly if you have spent alot of time researching you may have gotten the answer from them pronto.
Call Them @ TECHNICAL SUPPORTAvailable M-F 9:00am to 5:00pm CST
Toll Free - 800-556-3113
Fax - 708-427-3598
or worldsales@bodysolid.com
Jun 28, 2010 | Exercise & Fitness
Diagram for honda tmx155 electrical wiring
lay-out of honda tmx 155 electrical wiring diagram
Jan 11, 2010 | Pro-Fit Pro.Fit MI-3600 LoBoY w/miCradle...
Faulty Generator
check for open armature (check continuity at slip rings). Also check that diodes are good (not opened). Engine RPMs should be at least 1800 or 3600 depending on alternator. Probably 3600 RPM (for 60hz).
Also check to see if you have a bad circuit breaker.
Dec 07, 2009 | Electrical Supplies
I just changed the battery on a garmin ique 3600 and the backlight won't come on. Any tips?
Most likely you broke one or both wire from the backlight to the circuit board. Open the unit up and look for a black and red wire. Both should be soldered to the circuit board. LED's are used for the backlight and so it does make a different that the back and red wire are soldered to the circuit board correctly.
Oct 04, 2009 | Garmin iQue 3600 GPS Receiver
I have a 1995 oldsmobile 88 3600 series. The serpentine belt broke and I need a diagram to replace it.
the label should be on the frame near the radiator area lift the hood and look for a diagram
Aug 26, 2009 | 1995 Oldsmobile 88
What is the function of expended card.how many band width of mux 3600 single shelf,doul shelf.27LC card suport daat limit.why we use expanded card in mux 3600?and DINC card use for how many data sopor
You mean Expander Card.
The original chassis was fitted with only 6 slots and thus the control card can only manage these 6 slot single bandwidth. (2Meg per slot). As the 8 slot chassis was develop it was I think cheaper to build a new card as to build a new control card to manage the other two slot (7 and 8). So the expander card was build and to extend the shelf to 16 slots you do need the expander card fitted with a +16 expander module so that you can manage both chassis and provide double bandwidth per slot (4 Meg per slot).
There are two types of DNIC cards, nl. 6 circuit and 12 circuit. This card must be fitted with a DSP module if you want to configure the ports for 128K. Only 26XX DTU’s will work with this card. This card and DTU’s has been discontinued.
The 27LC2 card is a 6 circuit card and only 27XX and 2751/2/3 DTU’s will work with this card. This card and DTU’s has been discontinued.
The replacement for this card is the 27LC3 card and 27XX and 2751/2/3 DTU’s will work on them.
The 3600 mux is a single shelf which can be extended to a dual shelf. Each slot using a expander+16 can deliver 4 Meg. If only a single shelf is used you can fit a +8 module on the control card to provide you with 8 slots and 4 meg per slot.
May 11, 2009 | Alcatel Newbridge MainStreet 3600...
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
